It is currently Sun Jun 25, 2017 1:35 am
Post new topic  Reply to topic  [ 181 posts ]  Go to page Previous 14 5 6 7 813 Next
PostPosted: Sat Apr 21, 2012 3:19 pm
Do 1x NDS (heads in), 3x DS for triplet. 1x will be easier on the flange.
So long as the spokes have *some* tension, higher tension doesn't help anything.
PostPosted: Sun Apr 22, 2012 10:49 am
Hi rruff, what would be your thoughts for a non triplet ... thanks
PostPosted: Mon Apr 23, 2012 8:47 pm
If it's the hub with poor DS offset and a big offset ratio, 1x heads-in DS and 2x NDS would probably work best.
PostPosted: Tue Apr 24, 2012 4:19 am
Hi rruff, by 'poor DS offset and a big offset ratio' do you mean a wide flanged hub with a small DS flange or ??? ... thanks
PostPosted: Tue Apr 24, 2012 5:10 am
Poor DS offset means it is significantly less than it could be. ~19mm for S and ~17mm for C.
 Post subject: Light Alu Wheels
PostPosted: Mon Apr 08, 2013 9:42 pm
I've been eying the Canyon CF SLX. I'm not really settled on the Mavic Ksyrium SLR wheels, so will probably look to move these on and replace them.
I already own Campagnolo Neutrons, but they're starting to show their age and I'm not sure I want to put them on a beautiful new bike. Instead I'll look to retain these on the winter / all weather bike.
I'm 66-kg and no power house in a big gear. I tend to get my buzz in the climbs. So I'm looking for something responsive and light, with aero being slightly lower on the agenda (I know, I just described the Mavics).
A couple of alternative I'm considering:
HyperClinch SP - 1190g - £850
CERO AR30 - 1360g - £350
I have zero experience with these wheels and would welcome some feedback from anyone with experience. Clearly a significant price difference.
Thanks.
 Post subject: Re: Light Alu Wheels
PostPosted: Mon Apr 08, 2013 10:56 pm
How much do you weigh? What type of terrain are you riding? What do you expect to gain by getting new wheels?
http://www.zencyclery.com
PostPosted: Mon May 20, 2013 5:08 pm
Hi. New guy here. I ride a Merlin Extralight that I built around 1993. It weighs in at 15.8 lbs. and has 130mm dropout spacing. I LOVE this bike. It rides on Spinergy Rev-X tubular wheels using a 7 speed freewheel. The wheels and the bike are in exceptional shape and I love the trick look, so I want to keep them. I know these wheels are not particularly light, so I was thinking of having a second set of lightweight wheels for a different kind of riding experience, e.g., bursts of acceleration and quick spin ups. I weigh 135 lbs. so I don't need a gorilla strong wheelset. I'd like the wheelset to be as light as possible but roadworthy, on good quality roads.
What do you knowledgeable folks recommend? Are any wheels currently made that will work with my setup? I don't mind buying new.
Thanks for the help.
Mal
Weston, FL
'92 Merlin Extralight, 14.6 lbs.
'14 Giant Propel Advanced 2
PostPosted: Mon May 20, 2013 5:19 pm
I would go with a custom build of NOS Dura Ace 7400 hubs and H Plus Son TB14 rims, unless you want to stick tubular and you could go Ambrosio rims. CXRay spokes of course.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Mon May 20, 2013 10:39 pm
Are you set on running clinchers, or would you be willing to give tubulars a try? What is your price range?
PostPosted: Tue May 21, 2013 12:20 am
I'm currently on tubulars. I'm not opposed to staying with tubulars, but I wouldn't mind going back to clinchers either, if there isn't much of a weight penalty. My price range? Not sure how much $$ I'm willing to put into this. Depends on what's available.
Mal
Weston, FL
PostPosted: Tue May 21, 2013 4:17 pm
If you really want to experience light, then carbon tubular rims are the way to go. Unfortunately there aren't any light aluminum tubulars around. The Stan's 340 is just as light, and if you put light tires and tubes on there is really no penalty... except you will lose that tubular magic I guess...
formerly rruff...
PostPosted: Fri Apr 11, 2014 3:00 pm
I am new here and 1200...1300grams is light for 500.00...why don't more people go this route? Everything else i see is atleast twice that price and still low-mid 1400grams
PostPosted: Sat Jul 26, 2014 1:18 am
Hi all. I took a brief 2 year hiatus from the forums. No, it was not due to a prolonged hospitalization from these wheels exploding on me whilst careening down a descent. Simply chose to focus my time on actually riding.
I have put about 8000 miles on these wheels. What brought me back to this post is that I just now finished the first truing on these wheels (granted they probably needed it about 500 miles ago). As I sat their truing it I remembered that I shared this build on this forum 2 years ago. Over this period I initially used them just for road races, but gradually worked them into daily usage. I even raced these tubeless in a couple cross races last year. Never broke a spoke.
As far as upside: These are cheap, light and braking is excellent and predictable.
Negatives: After upgrading my crit wheels to 808 tubies, there is a huge difference between my wheelsets. Feels like the difference between riding an aluminum road bike on the hoods and a carbon time trial bike on my forearms. It always take a few minutes to get used to the feel again just swapping these wheels on the same bike. The aluminum clinchers definitely have flex hammering out of the saddle and the bike itself, predictably, feels twitchier. I don't find it spooky. Unfortunately, I don't have any other super light, shallow depth rims to compare these to. My comparisons are to my training anchors or to 50mm + deep carbon wheels. Comparing apples to oranges.
I would remiss if I didn't mention that my build inspired two of my mates to build the same. One assembled them himself, one went to a different builder in town. They both were 120-140lb mountain goats. They guy that built them himself has yet to break a spoke, but has trued them at least monthly since putting them together (I think he also used CX-rays). The other guy broke a number of spokes. I think 4-6 of them. He laced them with DT revolutions initially and I believe he eventually just sold the wheels off to someone rather than having them rebuilt.
Given that I outweigh these guys by 60-80 lbs, I think I owe about 99% of the credit for longevity to my builder. If anyone lives in Connecticut and wants his name, let me know.
-Snowstorm
"Good judgement comes from experience. Experience comes from bad judgement"
PostPosted: Tue Aug 05, 2014 6:13 am
I currently have a set of:
Kinlin XR-270
20/24 Sapim CX-Ray
DT240s front hub
PowerTap Pro+ rear hub
Thinking about getting a new wheelset for training and perhaps racing. I live an area with climbs nearby so ideally they'll be light and probably aluminum so I don't have to worry about blowouts? Additional requirements:
11-speed compatible
Lightweight
No PowerTap needed as I'm considering a Stages
Looks pretty :D
Budget ~$1k USD would be nice but if < $2k can get me something arguably nicer I'd consider it
What wheels would you recommend as an improvement over my current setup? What benefits would I be seeing? Overall I'm looking for a better ride experience. Should I go for custom or pre-built? Thanks!
There are no new unread posts for this topic. How are older Zipp 404 clinchers - aluminum brake track?
in Everything wheels
AJS914
Thu Mar 02, 2017 6:43 pm
gitsome View the latest post
There are no new unread posts for this topic. School me on uber-light clinchers
RQBL2016
25
3290
Tue Jan 10, 2017 1:04 pm
Multebear View the latest post
There are no new unread posts for this topic. Any suggestions on a light set of clinchers for everyday training, but..
sd5500
12
1505
Sun Oct 30, 2016 8:54 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Light weight rotors
in MTB
AllenMtb
13
1529
Thu Mar 30, 2017 4:05 pm
gtinut View the latest post
There are no new unread posts for this topic. Best light weight brakes for under $300
Sooperlite
27
2946
Fri Feb 03, 2017 12:04 am
Hexsense View the latest post
Users browsing this forum: No registered users and 3 guests
