Help needed from wheelbuilders for 24 spokes on 36 hole hub.
WMW
by WMW
You are right. It's been awhile since I've thought about this.
Which front hub pattern did I "pass along"? This one will work well for 20h, but I'm not seeing any good ones for 24h. viewtopic.php?f=3&t=91823&hilit=lacing+pattern#p790183
formerly rruff...
bricky21
by bricky21
You're right. It's been a while for me too since thinking about this stuff. The 20 hole patterns were what I was thinking of.
grover
by grover
Use the 36 hole hub. Lace it 2x both sides. Use 2.17 in the spoke calculation instead of 2.00. You skip every third hole. The spoke either side of the skipped hole angles towards that skipped hole.
KLabs
by KLabs
bricky21
by bricky21
Grover-that will not work. Read threw the thread to see why.
sawyer
by sawyer
I had a wheel built by legs11 on this forum a few years back along these lines ...
- P-X 50mm carbon tubular rim with 24h drilling
- 32 hole Campagnolo Record hub
16 DS and 8 NDS, missing every other hole.
Worked absolutely fine. One concern was the drilling was offset alternately (i.e. 12 holes offset one way, 12 the next), making it sub-optimal as some of the DS spokes entered holes they shouldn't have. But it worked.
That said it wasn't as stiff as the straight build I did (same rim and spokes) with a DA hub 12 each side.
bricky21
by bricky21
Yep, Triplet seems to work fine with 32 hole hubs. 24 hole patterns get complicated with a 36 though. Cryoplasm suggested an 18-6 early on, but my gut tells me that it wouldn't be suitable for anyone larger than a bantam weight.
grover
by grover
Bricky21 - because one side lines up perfectly and the other side is offset slightly? It just means the lead spokes are slightly shorter, the trail spokes are slightly longer...or vice versa depending on which way you build it. It's so minimal that it doesn't matter.
I've build a 36 hole Hope Pro 2 disc hub on a 24 hole Notubes Alpha 340 rim. I've been riding and racing cyclocross on it...that includes dirt road rides including water bars/getting airborne at 50-70km/h. I used the same spoke length for the lead and trail spokes on the slightly offset side. It's a little bit tricky to get even tensions as you can't just preset the depth of the nipples. Do a little fiddling, get even tension and you'll have a perfectly sturdy wheel build.
bricky21
by bricky21
Thing is there isn't any reason to use a spoke pattern that's out of phase when you can have a symmetrical 12/12 wheel with the pattern I drew up earlier. Lacing it 2 cross on both sides may be the only 24 spoke option the for a front wheel though.
