It is currently Sun Jun 25, 2017 1:26 am
Post new topic  Reply to topic  [ 5792 posts ]  Go to page Previous 1317 318 319 320 321387 Next
PostPosted: Thu Aug 21, 2014 3:18 am
I am curious why the fascination with 2:1 lacing. Are people experiencing problems with properly-built, sufficiently-spoked wheels using traditional 1:1 lacing patterns? Or is it just for fun? -- not that there is anything wrong with that, of course.
PostPosted: Thu Aug 21, 2014 4:51 am
It's pretty simple really... It can be a great way to deal with tension imbalance and the method has been used for donkeys years:
It keeps being mentioned that it's not particularly useful unless the hub has such a wide NDS that it's pretty useless for 'regular' lacing patterns.
Without opening up another can of worms, this seemed to be a great option for some people during it's short lived production run:
It seems like a bit of a shame that more manufacturers aren't interested in offering hubs/rims to suit when the concept has been proven to work so well.
PostPosted: Thu Aug 21, 2014 8:27 am
Hey thanks everyone. 28h 2x on both sides it is then, want to match the Shimano front hub.
PostPosted: Fri Aug 22, 2014 3:01 am
Ah, that makes sense about it being a good idea for very wide flanged hubs -- thanks. As effectively all my wheels now are disc brake, this is probably not in my near future. I guess I haven't had issues with wheel stiffness with "regular" (or disc) hub dimensions, but I also recognize that I may not know what I am missing.
PostPosted: Fri Aug 22, 2014 6:50 pm
How do I tell if a rim has offset drilling or center drilling? If it's offset, how do I tell the directions of the hole?
PostPosted: Sat Aug 23, 2014 6:04 am
Which rim is it? I've had rims that I didn't think were offset but Google said otherwise
PostPosted: Sat Aug 23, 2014 12:53 pm
I think we are just talking about the holes being offset alternating to match which side of hub those spokes would be laced -- not like a Velilocity OC rim. You can tell if the holes are alternating offset by just looking at the rim.
PostPosted: Sat Aug 23, 2014 3:22 pm
My fault, probably shouldn't get on here when I'm that tired. You're right though, you just look at the rim, usually the rim bed is a bit easier to see it.
PostPosted: Tue Aug 26, 2014 4:25 pm
Probably discussed before, but i tried to find it searching the forum but couldn't
Different spokes drive/Non-drive side,
Using stronger spokes on the drive side to the non drive side, As strength is less needed at the non-drive side, you can make lighter wheels. Maybe in some way comparable to the 2:1 pattern wich uses twice as much spokes on the drive side.
Anyone has usefull input on this? Thanks in advance
PostPosted: Tue Aug 26, 2014 9:18 pm
I do sometimes use sapim race DS and sapim laser NDS. Some think it helps prevent spokes loosening off but I don't think so as lateral wheel stiffness is reduced and therefore it will flex more so even though the thinner spokes elongate more the lower wheel stiffness mean they still end up loosening tension by a similar amount if the same spokes where used both sides. I think the main thing it does is improve torsional stiffness for that reason I think it is worth it. It does not replicate a 2:1 lacing pattern not even close.
www.thecycleclinic.co.uk
 Post subject: Tune hub spoke tension
PostPosted: Thu Aug 28, 2014 8:30 pm
I'm currently building up a set of wheels on Tune hubs. The mfg specs call for max tension at 100Kgf, which is a bit below my standard of 120 Kgf on the drive side. Are people adhering to Tune's recommendation, or are they sneaking it up a little knowing that tension will decrease when a tire is mounted and inflated?
PostPosted: Fri Aug 29, 2014 9:20 pm
If you build a wheel with 1000N DS it will fall apart so up the tension to 1200N.
PostPosted: Sat Aug 30, 2014 4:22 am
getting ready to get a new set of wheels. thinking of something like a 90r and 50f clincher. where is there a good place to order. looking at lightbicycle and carbon cycle. should i be going with the u shape and a 27 wide. might go with a set of rims and build up a set that way. also i have seen alloy braking surface or go something else
PostPosted: Sat Aug 30, 2014 10:27 pm
tubular or clincher. I have a set of light bicycle MTB tubular rims and they built up very well 330g too for 27mm wide and 24mm deep. I am not sure about alloy brake track as even big name brands can have them delaminate not sure if the chinese ones are any better or worse or just the same in this regard. I have carbon track track on my carbon rims and with Campagnolo pads they stop well enough in the wet in fact I can't much difference from some alloy rims I have used in the wet.
Wide is fine for clinchers but with tubular rim it does restrict you to wide tubs.
PostPosted: Sun Aug 31, 2014 1:16 am
these are the ones i'm looking at. what is your opinion
http://www.ebay.com/itm/TUBULAR-Wheels-CARBON-50mm-88mm-Front-Rear-3k-Matt-Road-bike-700C-Rim-Black-NEW-/171224588235?pt=US_Wheels_Wheelsets&var=&hash=item6d822c680f
was looking for ud instead of 3k but not that big of a deal i guess
There are no new unread posts for this topic. already covered in another thread...
in Everything wheels
ultyguy
Tue Sep 27, 2016 10:07 am
jekyll man View the latest post
This topic is locked, you cannot edit posts or make further replies. Doping Thread
mrgray
Sat Aug 13, 2016 7:16 am
Frankie - B View the latest post
There are no new unread posts for this topic. Attachment(s) Another Pedal Thread..
[ Go to page: 13 4 5 6 7 ]
3Pio
99
9025
Thu Jun 22, 2017 1:06 am
3Pio View the latest post
There are no new unread posts for this topic. Rivet ti Build Thread
thedonnydino
24
3577
Thu Oct 13, 2016 5:24 am
thedonnydino View the latest post
There are no new unread posts for this topic. UCI abolishing 3/1 rule thread
ultyguy
12
2352
Wed Sep 07, 2016 5:52 am
cyclenutnz View the latest post
Users browsing this forum: No registered users and 1 guest
