Zakalwe
by Zakalwe on Tue Aug 06, 2013 9:42 pm
Everyone's got a different opinion on rounding up or down, to be honest either length you've given will work just as well as the other. Measure how long the length of the threaded portion of a spoke is, and how long a nipple is, now add them together. This is the range of variation available when you tighten the spokes, and you're worrying too much about whether the spoke will be .3 of a mm one way or .7 of a mm the other side of "perfect".
So basically order the ones they have in stock.
OwenJames
by OwenJames on Tue Aug 06, 2013 10:39 pm
Thanks again!
OK, given this sound advice, I will go for the rounded down numbers. Nice and even in my mind!
Appreciated.
One more thing; looking at the numbers I have given, and considering I am using a Tune Mag 170 hub... do those lengths look correct? I would have thought the NDS would have been greater than 5mm longer than the NDS...
OwenJames
by OwenJames on Wed Aug 07, 2013 5:09 am
Oh yeah, in my search around for online spoke length calculators, one of the recommendations was the UBI one, here;
http://www.bikeschool.com/tools/spoke-length-calculatorNow, I may be being stupid here, but I can only see one input for flange diameter... My Tune Mag 170 has different diameter flanges on L and R, so how does that work (please correct me, whilst tutting, if I have made a schoolboy error!)
Zakalwe
by Zakalwe on Wed Aug 07, 2013 9:22 am
Depends on the flange diameters, but generally if they're equal then they aren't that much different in length regardless of dish. For example, if the flanges are the same diameter there should only be about 2mm of difference between the NDS and DS so don't expect any whopping difference between the two.
Try the edd calculator too, you can pull the Mig hub out of the list then put your own ERD in.
OwenJames
by OwenJames on Wed Aug 07, 2013 11:04 am
Thanks for the reply, and the hint about EDD Spoke Calculator.
I just used it and got the following;
DS = 270.6mm
NDS = 275.5mm
Given that, and given the other numbers I got from WheelProUK, would it be a good idea to round this up to 271mm and 276mm for the spokes?
Zakalwe
by Zakalwe on Wed Aug 07, 2013 11:57 am
CX Ray are quite thin as far as spokes go, so it depends on wether you anticipate them stretching at all. If you believe they will then round down, if you don't then round up.
Either way you'll be fine.
A lot of spokes only come in 2mm increments so its not unusual to knock off 0.5mm or add on 1.5mm in those situations, and many sound wheels have been built in the annals of time both ways.
wrcompositi
by wrcompositi on Thu Aug 08, 2013 2:58 am
DT's online calculator can compensate for the stretch of thin spokes, and the result is quite accurate. If the spoke's stretch is added to the result, I usually round down if the decimal number is less than 0.2, and round up otherwise.
allenpg
by allenpg on Thu Aug 08, 2013 5:47 am
I'm looking at building up a lightweight alloy clincher wheelset around a Powertap G3 hub. I'm about 150 lbs. Many of my wheels are 20/24 spokes. I was thinking of Sapim CX-Ray spokes with a BHS front hub. Mostly looking for rim recommendations or other ideas. These would be primarily for mountain climbing and descents (aka, why I want alloy brakes surfaces). Thanks!
-Pete
eric
by eric on Fri Aug 09, 2013 12:06 am
XR270 if you are ok with a narrow rim. The KinLin wide rims on BHS are nice but I think there are lighter options. I llke the UL66 hubs. The wider hubs are ok too but the slightly flexier wheel with the narrow flange hub doesn't bother me. I laced the last one 1x heads in and I think I like that. I've had spokes break on those hubs when laced radial heads out. My theory is that the spoke hole countersink on the outside leaves the elbow unsupported.
I weigh just 5lbs less and I am ok with 20h fronts but build 28h rears for training.
Burgunder
by Burgunder on Fri Aug 09, 2013 7:59 am
Since the XR-270 rims weighs the same as the Pacenti SL23 and only at litte less than the H Plus Archetype and HED Belgium C2. I would take any of those rims before the Kinlin rims as they are stronger and wider.
bombertodd
by bombertodd on Fri Aug 09, 2013 11:33 pm
I'm thinking about building my first set of wheels. I've been truing wheels on my bikes (zip tie method) for a while. I ride road, mtb, and race downhill bikes. Is the Park TS-2.2 still the industry standard for truing stands? I'm tired of the zip ties, and looking forward to learning how to build good wheels.
eric
by eric on Sat Aug 10, 2013 12:27 am
It's pretty nice. It is the shop standard. It'll last you the rest of your life and you can will it to your kids, assuming there are still bicycles with wheels then. However it does not keep center very well. It seems that when you adjust the arms from front to rear hub width a few times it loses center. So you also need a wheel dish tool or the Park stand centering gauge (or you can make one).
Less expensive truing stands will work fine too.
eric
by eric on Sun Aug 11, 2013 12:36 am
I prefer to make sure the stand is centered. It makes truing wheels easier.
If you get a Park dish tool, don't get the "portable" one. It's not, and it only works right if you don't have a tire on. The other Park dish tool looks like a much better design but I have not tried it yet... I bought the sucky one.
kavitator
- 1881 Replies
- 126044 Views
Last post by User Name
Thu Apr 19, 2018 7:44 pm
- 11 Replies
- 1555 Views
Last post by scant
Thu Jan 25, 2018 12:32 am
- 8 Replies
- 1152 Views
Last post by stevod
Wed Sep 27, 2017 6:09 pm
- 4 Replies
- 760 Views
Last post by Valbrona
Sat Sep 30, 2017 4:16 pm
