Zen Cyclery wrote:
@KLabs- The only thing that I've noticed with tied spokes is how difficult it is to replace a broken one. As far as rigidity goes, there is no real world difference, at least these days.
eric wrote:
With tied & soldered spokes, a broken spoke will stay in place and not jam in the frame or otherwise do something dangerous. So you can keep riding until you can get a wheel off the team car. That's the only advantage I can see.
Hi Zen Cyclery and eric, what about if only done on the NDS when the NDS tension where it is low (about 44%) ...
I have seen a rear wheel that uses plastic spoke ties (neat idea) ...
http://velostage.com/pro-lite-bracciano-review/ ... just page down a little (I can't get the img to work) ... [img ... how to add an image .../img]
Hmm ... yes, when the wheel is static (no torque, lateral, radial forces are being applied ... not riding) spoke ties don't do anything to address spoke tension or stiffen the wheel.
... but when torque, lateral, radial forces are applied (dynamically - while riding) this is when the mechanics of the spoke tie may have an effect on each spokes tension/detension cycle. For example, while one spoke is pulling and the other spoke is pushing (one spoke is in tension while the other spoke is in detension), and because these two spokes are tied, the 2 spokes should assist each other during each spokes tension/detension cycle.
If this is the case then each NDS spokes tension (while riding - sprinting/climbing) should remain tensioned even during the detension cycle (ie. closer to static tension)
Nonetheless, even if the spoke tieing does do this for a 2xNDS, a 3xNDS would still control torque effects better, improve the static NDS spoke tension, and make the wheel a little more compliant (give a better ride) ... now, if the previous analogy is correct then what would be the effect with 3xNDS and 2 spokes tied
What do you think ... sound reasonable
