The wheelbuilding thread
Forum rules
- in the industry
- Contact:
I think kinlin are making the best rims at the moment. In expensive and the wrok very well as rims. More expensive rims are just that, they seem to offer little elese but fancy stickers.
Just use sapim race or dt comps for a traiming wheelset. Forget the aero compsextra expensce for no gain..
Buy cheap stack deep. Learned that lesson with surplus ammo in the early 2000s.
I forgot to mention that while Aerolites measure close to 0.9x2.2, the range for 0.8x2.0 on the TM-1 chart was spot on until about the 100kgf mark where it started reading higher than measured. If I switched to the 0.9x2.2 range at 100kgf then it was back on track. For round spokes it was reliable, both 2mm and 1.8mm.
F45 wrote:I forgot to mention that while Aerolites measure close to 0.9x2.2, the range for 0.8x2.0 on the TM-1 chart was spot on until about the 100kgf mark where it started reading higher than measured. If I switched to the 0.9x2.2 range at 100kgf then it was back on track. For round spokes it was reliable, both 2mm and 1.8mm.
I have not used the tm-1 chart anymore, I prefer the park tool wheel tension app. I wonder if the tension figures in the app behave the similar way.
Hello everyone!
I am back, i got the hubs and the nipples now. I was able to measure everything. Now i have a question about the spoke length, as usual the different spoke calculators give different results. Before i buy the spokes, i would like to discuss, just to be sure (Yes, I respected that the different spoke calculators wan to be fed with different parameters)
Front wheel:
Sapim calculator: 282mm both sides
DT Swiss calculator: 281.7mm both sides
Prowheelbuilder calculator: 282.9mm both sides
Rear wheel:
Sapim calculator: 279 mm NDS and 284mm DS
DT Swiss calculator: 278 mm NDS and 283.4mm DS
Prowheelbuilder calculator: 279.1mm NDS and 283.4mm DS
Now, the problem 1 is that the spokes i plan to choose exist only in steps of 2mm length.
Problem 2 is, that for the CX-Super Spokes, one should choose the spokes, which are 1mm shorter than usual, because they are more elastic.
Now to get specific, i think that for the front wheel, 282mm spokes are the best choice. And for the rear wheel, 278mm NDS. But what length should i choose for the drive side? 282 or 284mm?
I would be happy if someone experienced could share his opinion.
Thanks a lot,
any123
Front wheel:
Rear wheel:
Thanks a lot,
any123
any123 wrote:Front wheel:
Rear wheel:
I would choose 282. The generel rule of thumb is to round down.
Putting together the parts for a cheap cx wheelset for my rim brake cx bike.
Got a new 5800 32 hole hubset on craiglist, with skewers, for $50 cash.
Ordered a set of WTB DX23 rims on ebay, $19.28 each, shipped.
The hubs are comically heavy. R 367g F 156g Skewers 125g.
The predictable next action would be to order some Sapim Race spokes for 50 cents each from Danscomp. But since I'm so far under budget I'm going to order some bladed spokes. CN 494s for the rear and 424s for the front. After I measure ERD of course.
My current set of wheels works ok, but they are 20/24, and I keep getting small sticks thrown up in the spokes. With 32 holes I'm hoping that will happen less often.
Total weight should be around....1900g.
wtf throw the hubs away and get a sub-300g set of Novatecs off Aliexpress for 70$!
