The wheelbuilding thread
Forum rules
- Contact:
I did not build his hand built set (LBS did) but I have tried truing and retensioning the wheels. The non drive side seems to have nipples coming loose even though the DS spokes are at 120kgf. I was thinking that Pacenti rim is a little flexy which is causing the spokes to go slack.
I wonder if a more elastic spoke (Sapim Laser? too thin?) would help here with NDS loss of tension? I would obviously heed whatever advice from folks that have some builds for heavier riders, though You can probably go higher than 120kgf on DS too, depending on the rim. I typically do 130-135 on the DS for Archetypes. And use nipple washers. Seems to be serving me (and the handful of people I have built wheels for) well. But no particularly heavyweight riders.
- Contact:
I tried 130 kgf on my SL23's and pulled a spoke through the rim. I wasn't using nipple washers though. I also noticed at higher tensions the rim starts to collapse creating dimples in the black part of the rim.
I've thought about using thinner spokes like the Sapim laser for the NDS to help keep tension on the spokes. The wheelbuilder at the LBS said they stretch easier but don't return (like a rubber band), but I recall reading they would return???
- in the industry
- Contact:
The pacenti rim is a racing rim it is not for 120kg riders. Not enough spokes for one. Hard tension limit of 1200n for this rim and i will only use alloy nipples with it as well now. I dont use washers i have found them un nessary if you limit rider weight and use alloy nipples and keep to 1175N +/-25N tension ds rear. Also 32H max only not enough spokes. The pancenti rim is a long way from being flexy so many misunderstandings above.
Lasers are a bad idea for this rider not stiff enough. You should use a triple butted spoke (or sapim race if you cant get triple butted spokes easily) and a 36h rear to ensure long spoke life. Spoke tesion drive side rear can be1200N. The archetype rim has a thick spoke nipple bed which is why i am sugesting it which means 1250 to 1300N is quite safe. Take my advise, i have done this wheelset before for 120kg riders and it works very well and it is the only one i recomend to such riders if they want somwthing that does not weight more than 2kg and performs well. If the rider want to save money in which miche primato hubs are used and these are fine hubs. Same recipe though, it works And the wheels dont break spokes or go out of true. So build this for your friend. If you build it properly you won't get problems.
- ultimobici
- in the industry
- Contact:
So, my Ryde Pulse Sprints are built up and have tyres fitted. The Open Corsa SC 25s come up very wide indeed - almost 28mm! God knows what Open Pave 27s would be! Probably going to swap them for some Open Corsa SR 24s I have, more for aesthetic reasons than anything else.
- in the industry
- Contact:
What width tyres. I thought the corsa sc tyres were only 23mm width, is there a 25mm. Never tried mounting corsa tyres on these rims Suprised they come up so wide. My 23mm corsa tyres are 25mm on my 25mm wide carbon rims.
What's the inner width on those rims?
Edit, found it, 17.8mm.
- ultimobici
- in the industry
- Contact:
Hubs are Stans No Tubes (by Novatec) 24/28 laced with Sapim Lasers & Prolock
- ultimobici
- in the industry
- Contact:
I'm not sure. Nut they look very similar. Front was 78g, rear came in at 225g.
- Samuel Sanchez Gonzalez
Funny, I just discovered Gianni Pegorretti's "new" brand 2 days ago and what do I see, a DeAnima for first time over the forum (I might have missed it in the past though). Lovely setup
- ultimobici
- in the industry
- Contact:
Hubs are Stans No Tubes (by Novatec) 24/28 laced with Sapim Lasers & Prolock Brass nipples.
With the tyres swapped out to Vittoria Open Corsa SR 25
Quick question, has anyone used nipple washers for internal nipples? My reasons are:
- bought slightly too long spokes, I know its ok for them to wind out a little, but would prefer to be on the safe side.
- I shined a torch on the internal carbon spoke bed, for some it is slightly uneven/mold-lines running across the hole.
Note: rim is Roval rapide Sl
Norwood & Adelaide Uni CC
