It is currently Tue Jan 17, 2017 6:08 am
Post new topic  Reply to topic  [ 3300 posts ]  Go to page Previous 1175 176 177 178 179220 Next
PostPosted: Mon Apr 01, 2013 1:51 pm
I've personally never bothered, although I have thought about it. I have never seen or heard of a study on that, maybe the forces generated by the speeds we ride don't create enough of a problem. Still, I do always put the magnet directly oppsite the heaviest part of the rim...
PostPosted: Mon Apr 01, 2013 3:13 pm
did some quick calculating...
if you're doing 60kph on tyres with circumference 2.132m, a 6g imbalance at 0.3m from axis would give about 3.6 newtons force
the wheel be 'lifting' then 'pushed down' ( and pulled forward/back/etc.) by the equivalent of c. 370g almost 8 times a second
assuming most weight is on the rear, it's the front that will be most affected, but that's still likely to be only 2-3% at most of the total downforce on the front wheel, so it's not going to lift off
it's the extent by which this force causes the tyre/etc. to deform that will determine how much vibration is caused
assuming i didn't mess up the sums, i doubt it's going to get close to the vibration from the road surface
PostPosted: Mon Apr 01, 2013 6:54 pm
Tubbie Guru
Hi,
You can most certainly feel the difference in the bike's handling when going fast enough.
Ciao, ;)
PostPosted: Mon Apr 01, 2013 7:11 pm
agreed, but only if the imbalance is big enough wrt the system weight
out of four sets of wheels, none balanced, but i only notice anything on one set at high speed on very smooth road
PostPosted: Tue Apr 02, 2013 12:10 am
Tubbie Guru
Hi,
If it makes a difference then it matters. It's about time we take the minor imperfections out of our bikes, wouldn't you agree.
We strive for perfection, do we not?
Ciao, ;)
PostPosted: Tue Apr 02, 2013 3:53 am
At speed it is perceptible if I focus on it. If I hold the bike by the stem and give the front wheel a good spin it is definitely noticeable.
I agree it's an imperfection, and I'd definitely like to correct it. If nothing else it's annoying.
Could also be the set of sh*tty tubs currently mounted as I wait for some Vittoria Corsa CX. I'll let you know if it goes away with a set a proper tubs mounted.
2012 SuperSix - 6.30kg
PostPosted: Tue Apr 02, 2013 10:24 am
tbh i'm in two minds about it, in my r&d days i'd take as long as it needed to tweak things and even choose electronic components on aesthetic grounds, when i moved to the development engineering group, the approach was: it's good enough, ship it - i did some ugly stuff in those days, and now i'm just a whore to commerce
adding balancing weights also offends my inner ww, but if i could get some negative masses, hmm...
PostPosted: Sun Apr 07, 2013 4:43 pm
Is Vredestein tubular cement just rebadged Mastik? The can even has the same light purple color...?
Link: http://www.bike24.com/1.php?product=35039;dbp=127;page=7;content=8;navigation=2;menu=1000,185,188"
tumblr
PostPosted: Mon Apr 08, 2013 12:31 am
Tubbie Guru
Hi,
Given that most Vredestein tubulars are manufactured at the same plant as Vittoria it would not come as a surprise if their cement is similar. I'd doubt it to be the exact same formula though.
When in doubt, use Masitk One. At least that's my motto.
Ciao, ;)
PostPosted: Tue Apr 09, 2013 11:23 am
Post Roubaix, a question: Was Vacansoleil-DCM partly on rebadged Veloflex Arenberg? A bit on the skinny side or?
Also, I mounted 3 Vittora Pavè CG (24mm) over the weekend for a club mate. Very easy to work with, and seemed to fill out the Zipp 303 "pavé", i.e. last gen. before Firecrest pretty well. Much better than the Veloflex Extremes he insisted on (also for gravel roads, pssst! flap flap flap) last year.
Bianchi-Campagnolo
PostPosted: Sat Apr 13, 2013 4:07 am
Does opened, but unused, Mastic One have a shelf life? If so, what is it? I'm trying to decide if it's worth buying the big can of it. I tried searching the site with google but didn't find the answer.
PostPosted: Sat Apr 13, 2013 11:10 am
Tubbie Guru
Hi,
Generally speaking it's not worth it to buy a can of glue unless you plan on gluing up dozens of tubs.
Once the can is open the solvents start to flash off.
Since you'll likely spill some glue on the can's edges it will then no longer be hermetically sealed allowing more of the solvents to evaporate.
The glue will eventually become thicker and thicker making it harder to spread on the rim bed.
Ciao, ;)
PostPosted: Sat Apr 13, 2013 11:20 am
^^^this
the last can i had was ok for about 4-5 months, i took care when refitting the lid, then the last 4-5mm got very thick, as above probably i'd got too much dried glue on the rim by then
but i'd used almost the whole can, so it was worthwhile vs. tubes
PostPosted: Sat Apr 13, 2013 1:37 pm
Thanks! That's very helpful.
Have either of you (or anyone else) tried transferring it to a squeeze bottle, as I've seen some mechanics do? I imagine that would eliminate the problem, as the small surface area of the tip could easily be cleaned off with solvant before recapping. This would have the added benefit of making application easier.
Example: http://www.youtube.com/watch?v=_Rjb-aWnbiY
PostPosted: Sat Apr 13, 2013 2:08 pm
I know you 've said it 100 times.. but one more quick recap for the newbie please..
New rims
->clean with acetone/gently sand
->apply thin layer on the whole rim on the center and sideways and leave it to dry for a few hours
->apply a second thin layer on the rim and leave dry again
->apply a layer on the basetape and mount it on the wheel while centering it fast
->pump tires to 130 psi and leave to cure for at least 24h
Correct?
Now about the spare tyre, how long do you leave the glue dry before you fold it? And do you fold it glue to glue?
Planet-X Nanolight HM - 5.63kg
There are no new unread posts for this topic. Reynolds 81 Tubular vs FSE EVO 79T Tubular , help!
xpert
Sun Jan 08, 2017 5:51 pm
xpert View the latest post
There are no new unread posts for this topic. Attachment(s) Show us your leg thread...
[ Go to page: 1 2 3 4 ]
PSM
52
8269
Tue Nov 15, 2016 9:59 pm
PSM View the latest post
There are no new unread posts for this topic. Another Pedal Thread..
3Pio
43
2595
Mon Jan 16, 2017 7:10 am
lw11 View the latest post
There are no new unread posts for this topic. already covered in another thread...
in Everything wheels
ultyguy
Tue Sep 27, 2016 10:07 am
jekyll man View the latest post
This topic is locked, you cannot edit posts or make further replies. Doping Thread
mrgray
Sat Aug 13, 2016 7:16 am
Frankie - B View the latest post
Users browsing this forum: No registered users and 9 guests
