Glueing tubulars [the tubular thread]
Forum rules
fdegrove
Tubbie Guru
by fdegrove
+ 1.000.000
Cheers, ;)
djconnel
by djconnel
Tufo tape adds about the same resistance as 200 grams added to your bike climbing a hill. If you look at Al Morrison's CRR results you might think it's no big deal but that's what it works out to. Would you use tires 200 grams heavier? So I recommend sucking it up and using Mastik.
I just got a Vittoria Crono CS to replace one which wore out. 189 grams on the scale puts a smile on my face. I feel like I'm cheating using these tires in hill climbs.
fdegrove
Tubbie Guru
by fdegrove
Hi,
[quote][/i'll have to admit that i don't think wiggins used Jantex tape. though he may have... :)quote]
I very much doubt it.
Jantex is really old fashioned tape, probably the first around. It's nothing more than a piece of cloth coated with white rim cement from I can't remember which company.
Anyhow, that cement isn't good at all and neither is Jantex tape really.
It's not even all that convenient to use, you invariably end up tearing that paper strip that's supposed to help center the tub anyhow....
What's so hard about putting a few coatings of cement on a rim anyway ? :?
If nothing else just do it for your own safety and that of others on the road along with you.
Cheers, ;)
bm0p700f
by bm0p700f
It still amazes me how many people think applying a bit of glue is difficult.
fdegrove
Tubbie Guru
by fdegrove
Hi,
That white glue I referred to is called Tubasti by the way. Avoid it like the plague.
That Jantex tape being a strip of textile weave which makes it hygroscopic (soaks up water etc). Not what you want from a tape at all.
And no, it hasn't changed and quite likely never will. What it should do is just disappear. :mrgreen:
Cheers, ;)
Geoff
by Geoff
Tubasti? Yikes. I remember that from my childhood. Really soft. Kinda the opposite of Clement, which was the other common glue of that era I would recommend avoiding.
PinaRene
by PinaRene
Who has tried the Vittoria Mastik ( Magic Mastik ) ?? I wan't to buy some next week to try it on my C50 wheelset and give it a try ...
jaup
by jaup
Hi,
I have just cleaned the adhesive on my tubs, what an arduous job.
So I'm just wondering how clean is clean enough?
This is about as good as I can get them.
Pics attached.
Sent from my Nexus 5 using Tapatalk
Geoff
by Geoff
@seahuston, sometimes, the area around the valve is not perfectly centred around the valve stem. This can leave a 'lip' of basetape fabric up against the valve stem. If this happens, that 'lip' of tape may result in the valve stem area may not lie flat on the rim bed. You should be able to see this on your stretching rim before you mount it. If your tire has a 'lip' of fabric, just trim it off with a razor knife until the tire lies flat when mounted on your stretching rim.
jorisee01
by jorisee01
jaup wrote:Hi,
Pics attached.
I think that's clean enough!
Multebear
by Multebear
What's the difference between Continentals rim cements for alloy vs. carbon if any?
parajba
by parajba
Hi all (in particular Geoff and fdegrove for all the help back in 2011-12!).
After a hiatus of 2 years I will be back racing in 2016 :) and I have a few questions.
Set-up: Zipp 404 dimpled pre firecrest, Veloflex Carbon (22? Can't confirm right now) from 2011, Vitoria Mastikone, glued in 2012 and raced very little, plus 2 unused Carbons 22c from same year. The 2 new Carbons have been stored in a shed on old clean rims, the Zipp 404s with the Carbons glued on have been stored inside my house in a dedicated (!) bike room.
Questions:
1) Is it safe to use the tires that were (properly) glued in 2012? I checked and the bond seems very strong. Glue is MastikOne.
2) I purchased 3 x 30gr of MastikOne and a few Vittoria PitStop cans in 2012 as spare, does this expire or will it be still good?
3) Because of the ageing process, I noticed that the side walls of the Carbons are a bit grey and not so supple, and perhaps in need of some liquid latex. I seem to remember that it's a standard procedure for the sides of aged Carbons?
Please note that I wasn't planning on ageing them for 4 years (!), it just happened that I had to take a few years off racing due to work commitments.
Thanks for reading!
fdegrove
Tubbie Guru
by fdegrove
Hi,
Good to see you back here, parajba.
1/ OK.
2/Ditto
3/It's the factory coating that oxidized a little, I'd just leave it.
I've a stash of Veloflex's that are much, much older than that and they're still fine. 8)
Cheers and thank you for the kind words, ;)
parajba
by parajba
Hi fdegrove,
Pleasure :)
