Tubular Repair
allenpg
by allenpg
I ended up with a sidewall puncture on my nearly new Vittoria Corsa X-Factors during a TT this weekend. I think it was some rough pave. I tried sealing it with Pitstop and Stan's, but no luck. Based on the photo, do you think this tire is repairable? I've used Tirealert.com for tread based punctures before, but never a sidewall. On the positive side, this was my first tubular puncture during a race in over 8 years...:) Thanks for the help!
-Pete
Geoff
by Geoff
Well, it is a bit tough to say from that pic, but it looks like the sidewall damage may be a bit more than just a 'scuff' and is through some of the casing itself (the casing is comprised of bias-cut, unidirectional 'sheets'). You can sometimes repair sidewall damage using AquaSeal, or other urethane-based sealant. You may be able to save the tire, but without being able to see how 'deep' that damage is, only you will be able to judge that.
The puncture tiself sounds like a pinch-flat, which can happen with tubulars, especially with the new deep rim beds. That is certainly repairable.
Good luck!
LouisN
by LouisN
OK. :cry:
I need some pictures of the right type of stitches to obtain a decent repair/regular shape on the tub...
The previous "typewriter caracters" explanation didn't do it for me... :oops:
Louis :)
sungod
by sungod
for the XXXXXXXXX pattern, there're some good pictures of it in this thread...
http://www.lfgss.com/thread92080.html
(though some people use a //////// pattern)
i've always used XXXXXXX, when you sew it, use the existing holes and make sure you pull the thread tight on each stitch
after gluing back the base tape, stick it on a rim and inflate to maximum pressure, the shape of the repaired area should be indistinguishable
btw find using a light coloured thread makes it easier to see what's going on when sewing, i got a reel of white 30lb dacron backing line from an angling supplier, cheap and works well
LouisN
by LouisN
Thanks for the link sungod :).
I'll try to do a better job on the next one, so the repaired area doesn't look like a twisted gut... :oops:
Louis :)
jekyll man
by jekyll man
Louis-
I just do a length of \ \ \ \ \ \ \ \ into the end of the original sewing, and then back the opposite way / / / / / / / /
Finishes off a reasonable XXXXXXXXXXX :thumbup:
Official cafe stop tester
svennn
by svennn
I picked up a new bike in the fall that came with a set of HED 3c tubular wheels in 650c with Conti Sprinter tubes glued on. As I've never owned tubular wheels I figured I would re-glue them so I would know they were done correct. The tires look brand new with next to no wear.
My problem is with the base tape. It is coming off around the whole circumference of one of the tires. I need to re-glue it but I'm having a hard time finding the appropriate glue. Maybe for the $15 or so I'm better off letting tire alert do the repair? Are they still in business? Pricing on the website is as of 2012.....
If not, what to use? Any kind of contact cement? Dap? I can't find Barge anywhere. I'm in the flooring business and I have a warehouse filled with various glues. Carpet, contact, urethane, you name it. I would just like to get it right.
Thanks.
Steve
dj97223
by dj97223
TireAlert was in business as of a few months ago, at least. They did a nice repair job on one of my tubulars.
svennn
by svennn
Just a follow up.....
Tire Alert repaired my base tape and got it sent back in good time.
Now to glue them up....
mulletmaster
by mulletmaster
Some great advice on here thanks.
bm0p700f
by bm0p700f
I was riding today and got a puncture on my competition tubulars, while this is not a problem where it is is. The puncture was under the base tape. How did it get there. Nothing went through the base tape. Tub at 90psi (25mm) and I hit nothing that could cause a pinch flat. What happened. Have not had chance yet to pull back the base tape and unsticth to take a look. I know it must be fairly big as the sealant put in there on Tuesday to seal up a pin prick puncture did not seal it. They had been doing so well up till now, except tuesday which does not matter much.
sungod
by sungod
i had the same happen last year on a veloflex carbon
noticed the front was losing pressure, i was in no hurry and it was an almost new tyre so i fitted my spare rather than use sealant
at home i eventually found a tiny puncture under the basetape with no hint what caused it, i just repaired it and all was well
Geoff
by Geoff
Well, while I have heard of that kind of failure, I have never actually seen it in person. It would not surprise me to see a tube that was either manufactured with a flaw (a bubble in the wall, or something like that), or got 'nicked' during the stitching or other manufacturing process.
It certainly doesn't seem to happen very often, but it's too bad that it happened to both of you. I hope it doesn't put-you-off, as I suspect that lots of people are looking at your posts prior to making the jump to tubulars.
sungod
by sungod
i wouldn't want to put anyone off, just a chance failure
certainly didn't make me consider swapping to clinchers!
11.4
by 11.4
It's not uncommon for the inner tube to be rotated inside the casing. The hole was actually somewhere exposed, such as a one-sided pinch-flat or even a tread puncture, but when the tire was cut open, the inner tube relaxed and returned to its unrotated position -- which meant the puncture in the tube moved somewhere else. That could sometimes be lengthwise in the tire, sometimes rotational. I've had this happen plenty of times. Often you don't even notice it because you only have a general idea of where the puncture is because air is leaking from a tread hole nearby but the actual puncture is an inch or two away.
