It is currently Sat Jan 21, 2017 9:02 pm
Post new topic  Reply to topic  [ 406 posts ]  Go to page Previous 119 20 21 22 2328 Next
 Post subject: Re: Tubular Repair
PostPosted: Mon Apr 15, 2013 12:03 am
Tubbie Guru
Hi,
It might be caused by the rim cement "working" (as in trying to adhere but having to let go at each revolution) but that would not make that kind of sound IME.
However, a Veloflex Carbon or any Veloflex tyre for that matter should not present a bulge around the valve area.
Maybe the tyre wasn't properly put on as in not pulled sideways enough as it was put on the rim?
Just guessing but that's what I suspect.
Maybe wiser minds than mine will come to rescue.....
Ciao, ;)
PostPosted: Mon Apr 15, 2013 9:13 am
if you take the wheel out, put it in a stand or hold it, then spin it, does it still 'tick'?
PostPosted: Mon Apr 15, 2013 9:16 am
it probably the valve sten hiting the rin.
cycling,a great individual sport,were you can't reach anything,whithout group effort.
PostPosted: Wed Apr 24, 2013 10:28 pm
It was the valve stem.
PostPosted: Wed Apr 24, 2013 11:11 pm
Tubbie Guru
:lol:
The usual suspect.
Glad you sorted it out. :thumbup:
Ciao, ;)
PostPosted: Wed May 15, 2013 2:24 am
EdEPS wrote:
I spent some time on an as good new Vittoria Corsa Evo SC which I got from a colleague. He tried to fix a small puncture with liquid latex but did not succced and he wanted to throw the tubular away.
After reading this topic and some other tubular repair topics on internet I openend the tubular for about 10cm of the valvehole, replaced the inner tube with a new latex inner tube (Vredestein), sewed it up again. Checked it and at last I glued the basetape back into place and put the tubular on a spare rim.
I inflated it up to 10 bar and it is holding with no bumps etc.
I only repaired a flat tubular once before so I do not have a lot of experience. But take your time, work carefully and do not hurry and you will succeed. Most member of the cycling club call me crazy for using tubulars. I agree that it takes more time compared to clinchers but it is no rocket science and I simply like the ride :)
By the way, I use Bison Kit as glue for the basetap which is, as far as I know, the same as Barge Cement.
http://www.bison.net/en/
If you have question about replacing an inner tube please let me know. Next time I will take pictures.
fdegrove wrote:
Hi,
I'm sure I have described the procedure a few times already, just don't seem to find it somehow.
Anyhow, here's the link mentioned by jekyll man:
http://sheldonbrown.com/brandt/tubular-repair.html
Scroll down to "Tube Replacement".
Ciao, ;)
I did replace the inner tube of a tire,sorry but no pictures.
thanks to every one,if possible soon i will make some pictures of how to proced.
 Post subject: sad news
PostPosted: Mon Jul 01, 2013 11:42 am
i was about to send some tubs for repair to http://www.tubular-repairs.com/
sadly there is a message that Peter Burgin died on the 17th of June
for anyone wishing to make a contribution, his chosen charity is the British Heart Foundation http://www.bhf.org.uk/get-involved/donate.aspx
PostPosted: Sat Jul 13, 2013 1:40 am
I just took a tub off it's rim after more than 4500 km's of work :beerchug: ...
I'm wondering (it's been probably discussed already somewhere in here, but I can't find it), anybody used the tubular latex tube in a clincher ?
Thanks for the info,
Louis :)
PostPosted: Sat Jul 13, 2013 5:39 am
Tubbie Guru
Hi,
No problem whatsoever. Recycle. 8)
Ciao, ;)
PostPosted: Fri Jul 19, 2013 5:34 am
I am confusing to compare the TireAlert use latex tubes and not able to make a decision about it. How is it possible to check it?
Click here
PostPosted: Fri Jul 19, 2013 1:05 pm
I think what you're asking is whether Ron at TireAlert will use latex tubes or not. The answer is: yes. If you provide him the tubes, he will use them. He still will not take responsibility (rightly) for the size. One of the guys on this Board just got tubulars back from Ron and he used latex Vittoria clincher tubes. No problems.
PostPosted: Sat Jul 20, 2013 11:08 pm
Tubbie Guru
Hi,
AFAIK Ron uses butyl inner tubes per definition. If you want him to use the inner tube of your choice you simply send it along with the tubbie to repair and he'll then use that.
No idea if he'd charge extra bucks or whatever but it can be done.
Ciao and greetings to Geoff, ;)
PostPosted: Sun Jul 21, 2013 2:10 pm
fdegrove wrote:
Hi,
Ciao, ;)
The Vittoria latex tubular inner tube is 42 g, opposed to a Vittoria clincher latex tube at 70 g :shock: .
Feels waaaayyy thinner too. I'll have to be careful that the rim bed and inner side of the tire are impeccable with this tube...
Louis :)
PostPosted: Sun Jul 21, 2013 8:20 pm
Louis, that is 100% correct. They are also smaller. Unfortunately, latex tubes for tubular tires are hard to come by, which is why Ron doesn't 'stock' them.
PostPosted: Mon Aug 05, 2013 2:44 am
I put them inside a 23mm open tubular. Doesn't hold air for very long. After one hour, it already lost 50 PSI. Too stretched I guess...
Probably would be better to put them inside some 20mm tires.
Louis :)
There are no new unread posts for this topic. A positive plug for Tire Alert Tubular repair
in Everything wheels
skiezo
Wed Jan 27, 2016 3:48 pm
skiezo View the latest post
There are no new unread posts for this topic. Has anyone gone through WARRANTY or CRASH REPAIR with ASSOS?
g32ecs
10
760
Sun Jan 15, 2017 2:29 pm
robo View the latest post
There are no new unread posts for this topic. look keo blade carbon-ti maintenace/repair
rickytek
Fri Feb 05, 2016 8:15 am
rickytek View the latest post
There are no new unread posts for this topic. Search: Lightweight wheel with broken spoke! To repair!
Carbonwork
Sat Apr 23, 2016 7:47 pm
Carbonwork View the latest post
There are no new unread posts for this topic. Reynolds 81 Tubular vs FSE EVO 79T Tubular , help!
xpert
Sun Jan 08, 2017 5:51 pm
xpert View the latest post
Users browsing this forum: No registered users and 5 guests
