It is currently Fri Dec 15, 2017 3:35 pm
Post new topic  Reply to topic  [ 433 posts ]  Go to page Previous 19 10 11 12 1329 Next
 Post subject: Re: Tubular Repair
PostPosted: Thu May 19, 2011 2:13 pm
Hi,
thanks everybody for the valuable information.
Made me try to repair my dear conti comp, done most of the job OK.
Now for bonding the basetape, is copydex(or latex glue) the only way or I can get away with my vittoria rim glue?
PostPosted: Thu May 19, 2011 11:51 pm
Tubbie Guru
Hi,
You can be you should not.
If you can get hold of Copydex use that, if not Jevelot or any other liquid latex which can often be found at art shops.
Ciao, ;)
PostPosted: Sun May 29, 2011 6:57 pm
Hey fellow tub peoples...
Liquid latex: where to get it stateside?
Every hardware store or art supply place I walk into just looks at me strangely when I ask about it. Is it known by any other name perhaps?
I got some tires with plenty of tread but tired sidewalls that could use some love...
The Chronic
PostPosted: Sun May 29, 2011 7:10 pm
google "jevelot tire life". You'll see internet buying oppotunities.
PostPosted: Mon May 30, 2011 1:46 pm
World Class Cycles!
PostPosted: Mon May 30, 2011 2:07 pm
Well, I was trying not to name names, but yes, that does come up on the first link with my proposed googling.
PostPosted: Mon May 30, 2011 3:10 pm
Roger knows good product, has reasonable pricing and fast delivery.
PostPosted: Mon May 30, 2011 11:17 pm
Tubbie Guru
Hi,
Is there any difference between Jevelot and ordinary liquid latex you guys know of?
Just wondering...
TIA, ;)
PostPosted: Thu Jun 16, 2011 1:36 pm
sorry if I missed it, 11 pages has me a bit cross eyed.
How do you fix or fill the cut in the tire? I've patched several, but the cut always seems to collect debris. My latest one is holding fine but after my last ride I inspected the cut and it had several sharp pebbles imbeded in it. I've learned to patch the casing from the inside with a piece of nylon or other strong fabric, but I worry even this is no match for a pebble stuck in the cut and a long ride.
I've tried to just use mastik in the cut but it never holds. I though maybe superglue but don't think that will be any better.
Thoughts?
PostPosted: Thu Jun 16, 2011 2:45 pm
Zap-A-Gap was recommended on p. 8 viewtopic.php?f=3&t=70013&p=692013#p692013
PostPosted: Thu Jun 16, 2011 3:00 pm
Unfortunately, tread cuts cannot be easily dealt with. I have tried 'Shoe-Goo' that I use on my hard-court shoes. It works ok, but has to be re-applied quite regularly. On small cuts, it is as close as you will get to a permanent solution. Other than that, I have found no better options.
PostPosted: Thu Jun 16, 2011 10:50 pm
Tubbie Guru
Hi,
Loctite's Superglue Flex Gel Max contains rubber and works fine.
I guess you're on Vittoria or similar tubs? Try Veloflex, they don't pick up flints at all. 8)
Ciao, ;)
PostPosted: Fri Jun 17, 2011 3:33 am
Actually it's a Veloflex Carbon. I think the cut was made by glass or metal since I was in beautiful Downtown Detroit when it happened. I picked up the sharp rocks on a ride after I had repaired the tube.
PostPosted: Fri Jun 24, 2011 12:13 am
Tubbie Guru
Hi,
When's the funeral ? :(
Stuff like that happens. You know that. 8)
Ciao, ;)
PostPosted: Fri Jun 24, 2011 3:07 pm
Tug Boat wrote:
http://www.tirealert.com/
TB
FYI...I tried emailing these guys about repairing Vittoria Corsa CX 3210 TPI with the removable valves...never got a response...maybe they aren't in business although the website is still up.
There are no new unread posts for this topic. SRAM Red RD repair
thePrince
Sun Aug 27, 2017 4:07 pm
sungod View the latest post
There are no new unread posts for this topic. Campy EPS Charger Repair
wjshook
Mon Nov 27, 2017 11:28 pm
Disc0 View the latest post
There are no new unread posts for this topic. Campagnolo EPS V2 Battery Repair
Diverse
Sun Mar 19, 2017 5:11 pm
ferrarista View the latest post
There are no new unread posts for this topic. Time to weenie the repair kit.
Shrike
28
3242
Fri Jun 16, 2017 11:18 am
punk View the latest post
There are no new unread posts for this topic. Attachment(s) DIY Carbon fiber repair - seatstay.
BikeAnon
40
5370
Thu Nov 02, 2017 1:45 pm
BikeAnon View the latest post
Users browsing this forum: No registered users and 10 guests
