Tubular Repair
fdegrove
Tubbie Guru
by fdegrove
Hi,
Never heard of that before.
I suppose the extra protection is welcome for the cyclo-cross guys.
Never experienced a pinch flat with a tubular on the road so what do I know. :lol:
Ciao, ;)
EDIT: According to someone at Velonews (Zinn) Dugast uses silicone/latex inner tubes in conjunction with tubulars for MTB use.
http://velonews.competitor.com/2010/12/cyclocross/technical-faq-with-lennard-zinn-the-limits-of-sealant_152087
Geoff
by Geoff
Hmmm. That's interesting. They must be a special production item.
fdegrove
Tubbie Guru
by fdegrove
Hi,
Possibly.
I honestly don't see the benefit for road use. Do you?
Ciao, ;)
Geoff
by Geoff
I have to say that I have no idea! I would sure like to get my hands on some to try, though...
BERNARDO
by BERNARDO
uhmmm interesting thread.
jferrell14
by jferrell14
Have been looking for a UK based Tire Alert for a while and just came across this: http://www.tubular-repairs.com/
Anyone got any experience with this service?
I'm looking to repair some 650c tubulars, what are the chances of finding the right inners...? :roll:
Jack
fdegrove
Tubbie Guru
by fdegrove
Hi,
By inners you mean inner tubes for the 650C tyres?
Butyl or latex?
Ciao, ;)
jferrell14
by jferrell14
Yes innertubes, Butyl for my trainers, but whatever is easier to get hold of.
Jack
fdegrove
Tubbie Guru
by fdegrove
Hi,
Assuming the inner tube is beyond repair and in need of replacement I don't see why you can't use a common 700c one and shorten it to fit your needs?
Ciao, ;)
Ypsylon
by Ypsylon
The matching 650c tubes should be commonly available, the first online shop I checked has them.
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
icebreaker
by icebreaker
My apologies if I missed the answer, but did I read right ( somewhere a number of pages back) that Tire Alert does NOT use tubes with a removable valve core??
Tibber67
by Tibber67
Tire alert will use either a standard tube or a removeable core tube for $3 more.
http://www.tirealert.com/tirealert/Prices.html
icebreaker
by icebreaker
Tibber67 wrote:Tire alert will use either a standard tube or a removeable core tube for $3 more.
Thank you,
completely overlooked that.
woodys737
by woodys737
Just wanted to add that I've had great workmanship and service with Ron at Tirealert. Only advise is that the white base tape he uses (not sure how much of a choice exists) soaks up a ton of glue. When the tire was worn out I had a hell of a time pulling it off. When I did a good amount of the base tape stayed adhered to the rim rather than coming off with the tire. Not a huge deal, but made prep time for the next tire a whole lot longer.
As always my technique might have been the problem more than the type of base tape. I usually give the tire a coat of glue and let it soak in and dry for at least 24 hours before further applications and mounting.
fdegrove
Tubbie Guru
by fdegrove
Hi,
I suspect a number of factors are at play here. First of all the glue used on the base tape may well not have had enough time to properly cure.
Second, well without further information I'll skip that.
But on all counts the bond between tyre and base tape should always be stronger than the one between base tape and rim for obvious reasons.
Ciao, ;)
