It is currently Sun Jun 25, 2017 9:59 am
Post new topic  Reply to topic  [ 169 posts ]  Go to page Previous 15 6 7 8 912 Next
 Post subject:
PostPosted: Sun Jan 20, 2008 3:56 pm
chrism wrote:
sawyer wrote:
No. Drag while freewheeling most certainly is relevant. It's one of the reasons I didn't get on with an AM classic rear hub. Think about it, who uses less power, the guy with the draggy hub or the guy with DA/Record hub?
Only if you take part in coasting races!
The object of any race is to pedal as little as possible (save energy). There are many situations (not just downhill) in races where you coast as long as possible in the draft. Less friction means you can wait longer before you must pedal again to maintain the gap.
 Post subject:
 Post subject:
PostPosted: Mon Jan 21, 2008 1:22 pm
I'm not convinced races are won or lost due to soft pedalling.
No scales on the trails
 Post subject:
PostPosted: Tue Jan 22, 2008 12:03 pm
i can understand the concept sounds ridiculous, but conserving energy in races could mean the difference between winning and losing, and certain in a sportif type event will help your time (a bit). I also just enjoy the freewheeling madness that a smooth low friction hub gives you.
 Post subject:
PostPosted: Sat Mar 22, 2008 3:07 pm
Who sells Extralite Ultraclimb Clinchers in the US?
 Post subject:
PostPosted: Sun Mar 23, 2008 1:18 am
Might be able to order through:
http://www.sales.light-bikes.com/extral ... 0Wheelsets
Or, contact Sergio Riva @ Extralite directly.
studioriva@extralite.com
EDIT: Extralite's site notes they are "not available."
 Post subject:
PostPosted: Sun Mar 23, 2008 3:47 am
Thank You!
 Post subject: Light wheels
PostPosted: Mon Mar 24, 2008 8:16 pm
Look at the price of this high-end 'prototype' rubbish. I mean, these companies may have spent loads of money on testing and claim to offer the lightest stuff but so do Zipp and their product is junk.
I have built countless pairs of Mavic Open Pro's on Record hubs and depending on how you do it (taking rider weight, frequency of use and road type into the equation) you can get a 1380-1500g set of bullet-proof wheels that you can fit and forget.
I have tried LOADS of carbon rimmed, low spoke count, ultralight combinations and NONE give you that re-assuring feeling when battering down a rutted descent in a punishing race.
Reynolds wheels suffer from spoke breakage - Lightweight, the same. Zipp are expensive junk and factory-builts are for sponsored teams. Its all a big con. And, in the case of a friend of mine - it can nearly cost your life! (Stratus DV UL spoke breakage). So what if they fix them under warranty?
Get a set of decent - time-proven components together ie: 32h Ambrosio Excellence or Open Pro / Reflex in 32h and lace them up with Record hubs with Sapim Lazers and you won't look back. You will, however always lust after lighter, more problematic hoops so you'd better either get them to satisfy your lust and use them sparingly or get some medical help for your obsession.
Uber-light wheels are like beautiful ladies. They cost a king's ransom and you wish you had a rougher version when riding them. (Sorry!)
 Post subject:
PostPosted: Tue Mar 25, 2008 12:17 am
^^^^ good post :-)
 Post subject:
PostPosted: Tue Mar 25, 2008 12:25 am
You have some points but it's a bit extreme. If it's all a big con, we all should be back riding on box rims ? No thanks.
 Post subject:
PostPosted: Tue Mar 25, 2008 12:56 am
dont knock box rims strob :wink:
tikka
 Post subject:
PostPosted: Tue Mar 25, 2008 1:04 am
hehe I am not knocking them. But I don't want to ride just that either!
 Post subject: Wheels
PostPosted: Tue Mar 25, 2008 8:57 am
The box sections are still used - check the Paris-Roubaix this year and see if you can spot them. Rasmussen was using 28h GP4's on DuraAce hubs a few years ago.
But I'm talking about easily available rims here. I got a load of Rigida rims in recently and they weigh a fair bit less than the claims. They also build up really tough AND, theres a beautiful lady on their website.
Well.....shes not bad althought she looks like shes got a bit of a moustache. Probably a mountain biker. Or a lesbian.
PostPosted: Sat Jun 29, 2013 1:50 am
Figure this topic is worth a gravedig (and has been added to the Road Index), as it's still relevant.
And stuff has improved from when the last posts were made.
http://www.nicksquillari.com.au
The Gram
The Men of Steel
PostPosted: Sat Jun 29, 2013 5:49 am
all the haters are going to cry, but try a set of mad fiber wheels. no weight limit and lighter then 1300gm as clinchers
PostPosted: Sat Jun 29, 2013 11:23 am
Instead of posting a completely new topic, I thought I might get my questions answered here.
77-78 kgs, sprinter kinda guy, looking for a wheelset that can be used for climbing, but also sturdy enough to be used for training.
Would like to keep it sub 1300 grams, and already have an option that involves:
Tune Mig45/Mag170 hubs
Sapim CX spokes - 24/28
Criterium rims - looks like a Kinlin XR200
Just below 600 euros.
I want to keep it clincher, as I never got around to being a fan of tubulars.
So my questions are:
1. I read something about Stan Notubes had some failure issues when used as clincher - anybody can confirm this? Or would that be a good rim as well?
2. Should I go with a 24/28 option due to my weight/power? Or can I go lower than that?
3. What other hubs are similar to the Tune Mig45/Mag170 in terms of weight/durability?
4. Would there be any idea in taking a rim with a slighty higher profile, such as a Kinlin XR270, which should be stiffer, and then go with a lower spokecount?
I had a set of Dura Ace C24 clinchers that were good. A tad flexy under load, but worked good for climbing.
If you dream of being famous - think of what birds do to statues.
Instagram: https://www.instagram.com/kermithimself/
Youtube: https://www.youtube.com/channel/UCdCPaXwpeXT_LpuEF0REjqw
Facebook: https://www.facebook.com/gotlegscycling/
There are no new unread posts for this topic. Any suggestions on a light set of clinchers for everyday training, but..
in Everything wheels
sd5500
12
1506
Sun Oct 30, 2016 8:54 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Fuchs Litespeed Vortex - 6140g - the everyday racer
[ Go to page: 1 2 3 4 ]
Fuchspk
52
5806
Mon Mar 27, 2017 10:25 am
Tomstr View the latest post
There are no new unread posts for this topic. Top end aero clinchers
Kermithimself
27
3236
Sat Oct 29, 2016 11:11 pm
sd5500 View the latest post
There are no new unread posts for this topic. New Shimano Clinchers
mariovalentim
Sat Jul 16, 2016 9:34 pm
phlip View the latest post
There are no new unread posts for this topic. Schmolke TLO 45 Clinchers
singlepush
15
2973
Fri Apr 21, 2017 9:30 pm
Marin View the latest post
Users browsing this forum: No registered users and 6 guests
