DT Swiss freehub body
wheelsONfire
by wheelsONfire
Anone knows if it's same freehub body on 240S MTB wheels and Road bike ditos?
Bikes:
Open *UP* (2016.04.14)
sungod
by sungod
same i think, to be sure you can compare here https://dycteyr72g97f.cloudfront.net/up ... EN_001.pdf
what may differ is the end cap, but you can re-use your old end cap
bm0p700f
by bm0p700f
the road bosy is 11 speed and the MTB freehub is 10 speed or 11 speed MTB. Different freehub lengths and different DS end cap. Also the OLD of the road hub is 136mm whereas the MTB hub is 135mm.
The freehubs are interchange able between the two though. The MTB hubs wont accet a campag freehub but the road hubs will.
wheelsONfire
by wheelsONfire
Thanks, i was looking at the 15*100 (front) and the 12*142 (rear).
I know that a road freehub body can be fitted with a MTB cassette. But the other way around will not work.
I thought DT Swiss used same body on both Road and MTB hubs.
Bikes:
