Fulcrum Racing Zero Competizione or shamal ultra ?
oraclesin
by oraclesin
i want's buy low rims. Fulcrum Racing Zero Competizione or shamal ultra ?
can you help to me.
mrlobber
by mrlobber
The same wheel basically, just different branding.
Mr.Gib
by Mr.Gib
yes, the same. The question is only if you can live with the red colour and if you think that Campy wheels should only go with a Campy drive train. In that case if you have Shimano or Sram you may prefer the Fulcrum. I have Shamal Ultra - fantastic wheels.
oraclesin
by oraclesin
Mr.Gib wrote:yes, the same. The question is only if you can live with the red colour and if you think that Campy wheels should only go with a Campy drive train. In that case if you have Shimano or Sram you may prefer the Fulcrum. I have Shamal Ultra - fantastic wheels.
but shamal ultra is USB bearing. and Fulcrum Racing Zero Competizione is CULT!! ... it's same?
oraclesin
by oraclesin
mrlobber wrote:The same wheel basically, just different branding.
i heared that two brands share technology. but USB bearing vs CULT bearing.. it's different.. so i just curious about bearing performance
mrlobber
by mrlobber
You won't be feeling ANY difference, period. Both are superb.
TonyM
by TonyM
I have the Bora ONE (USB) and the Bora ULTRA (CULT). When you spin the wheel you will see a difference but when I bike I don’t feel any difference however. The pricing is however quite different.
Difference between some Campy and Fulcrum wheels is also the lacing of the spokes (G3 for the Campy)
Mr.Gib
by Mr.Gib
isn't the difference just that CULT have hardened cups and cones, USB does not? Same bearings though? Difference might be longevity. Speed difference? that would be spitting hairs - don''t think there would be any. If the two feel different in your hand it is most likely due to type and amount of grease in the bearings assuming seals are the same.
TonyM
by TonyM
Mr.Gib wrote:isn't the difference just that CULT have hardened cups and cones, USB does not? Same bearings though? Difference might be longevity. Speed difference? that would be spitting hairs - don''t think there would be any. If the two feel different in your hand it is most likely due to type and amount of grease in the bearings assuming seals are the same.
Yes! both are extremely smooth! I can't feel any difference on the road.
I do however "feel" the difference between the USB/CULT Fulcrum/ Campy and the Mavic or 3T wheels I have.
CULT:
https://www.campagnolo.com/WW/en/Techno ... technology
USB:
https://www.campagnolo.com/WW/en/Techno ... h_bearings
