Record freewheel play
I have a modern Record hub which has developed play in the freewheel (only used for 4000Km ) I can rock the cassette (towards and away from spokes) noticeably, maybe 0.5mm of travel. It doesn't affect shifting yet but I would like it fixed. I removed the freewheel to clean and regrease and found the nut was very very loosely tightened. After I put it back together, same play. I wonder if I need just new pawls or the entire frewheel. Thanks!
Thank you! Will check it and see if i can punch it out. In. The mean while i could try taking the whole thing from my idling but new Vento hub, they look very similar and might fit.
