It is currently Thu Jan 18, 2018 5:09 pm
PostPosted: Sun Sep 24, 2017 9:17 am
I've got a DT 240 CL (28h) hubset and are planning to build new wheels for racing and light trail riding, and need some advice.
Rim:
I guess asymmetric and around 25mm inner width is the way to go? I've looked at these alternatives:
- Nextie, 26.5mm inner width, 390g
- XMCarbonspeed, 25 mm inner width, 360g
(What are your experiences with XMCarbonspeed? Do they have the same good reputation as Light-Bicycle and Nextie?)
- Any other suggestions?
Spokes:
The plan is DT revo and alu nipples, but should I go 2x or 3x? (28h)
PostPosted: Sun Sep 24, 2017 8:01 pm
Or maybe these from CarbonBicycle.cc? 320 grams and 24mm inner width. I've never heard of them before, any experiences on this great forum?
PostPosted: Sun Sep 24, 2017 10:53 pm
I am skeptical about carbon and the rigors of mountain biking.
I just had an aluminum set build by prowheelbuilder using velocity rims and American classic hubs. The thing is I want them to last.
Depending on your weight and the abuse and how long you want them for.
PostPosted: Mon Sep 25, 2017 8:46 pm
You're joking, right? Who doesn't ride carbon mtb rims these days?
PostPosted: Tue Sep 26, 2017 3:10 pm
Exactly my point.
Carbon frames crack all the time. You Get a replacement. Wheels will not last longer than a frame. You get a replacement.
Things that need to be replaced generate cash flow. Then we can also talk about consumerism and all that.
All the end things that are not long lasting but give you better performance is the current trend in cycling and in consumer society. You need to replace things to create revenue.
Just because all people have them doesn't mean they are long lasting. I use carbon rims on road bikes. Custom made. Last me a long time.
I will not risk it with a mountain bike. Being 200lbs and strong rider has taught me that mass production wheels break a lot faster than custom made.
PostPosted: Wed Sep 27, 2017 4:44 pm
XM carbonspeed - 360g rim, i25mm
Stans Arch - 425g rim, i26mm
I'd just use Arches, Revolutions, aluminum nipples.
2x will give you a slightly better bracing angle, but it's a wash really.
PostPosted: Wed Sep 27, 2017 7:27 pm
I ended up with these from Carbonfan.com, which is the same as the Carbonbicycle.cc-rims I mentioned above, just at a lower price. The wheelset will end up at around 1280 grams with revolutions and aluminum nipples.
A wheelbuilder I talked to recommended 2x/3x with 2x on DS rear and disc side front (3x on NDS and right side on the front wheel), any thoughts on that?
PostPosted: Thu Sep 28, 2017 12:19 am
3x all round. 2x makes no sense unless you use pseudo junk physics to justify it. I am being blunt.
Lateral stiffness with 3x is just fine. 3x maximises torsional stiffness which is important.
Also 2x on the fron disc side where all the braking torque is reduces the torsional stiffness. your builder has things backwards. I am being blunt again.
www.thecycleclinic.co.uk
There are no new unread posts for this topic. Advice needed from experienced WW
Mtek
Fri Aug 11, 2017 6:15 am
stormur View the latest post
There are no new unread posts for this topic. Advice needed on RS-1 Brain fork
in MTB
LegendRider
Thu Jul 27, 2017 7:24 am
bas View the latest post
There are no new unread posts for this topic. Rim brake advice and feedback needed
woogie11
11
905
Sat Aug 26, 2017 11:40 am
Marin View the latest post
There are no new unread posts for this topic. Style Police / Emotional Advice Needed
[ Go to page: 1 2 3 4 5 6 ]
JackRussellRacing
85
8818
Mon May 29, 2017 1:38 am
BennyC View the latest post
There are no new unread posts for this topic. Rim width for gravel revisited, advice needed.
simplemind
Sun Jan 14, 2018 10:49 am
jemima View the latest post
Users browsing this forum: stormur and 5 guests
cron
