Tubular PSI on wider rims
misterq
by misterq
So what are people riding PSI wise for races like crits , RRs and such on their tubulars that are wider.
I have aero 58s with Veloflex Roubaix on them, and 100 PSI felt bit much.
kytyree
by kytyree
I ride my VR's at 90 in the back and 85-90 in the front. This is the first set of the wider 25's I've had, but I've had the 24's in the past.
I'm very happy with them so far, and these pressures seem pretty good to me.
euan
by euan
Changing the width of a tubular rim doesn't affect the volume of the tyre like a wider clincher rim does.
And by that I mean at all.
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
sawyer
by sawyer
100 - 110 psi
Just the same as with 22/23s ...
dj97223
by dj97223
OP, I think PSI info is a bit meaningless without knowing the weight of the rider. How much do you weigh?
Geoff
by Geoff
I would tend to agree with that. I weigh 59-60 and run 25s on some rear tires. I find that there is no problem running them under 100 in the dry. There seems to be enough volume to prevent them from pinch-flatting on the deep rimbeds seen on many of the modern aero wheels.
RyanH
by RyanH
At 70kg I run the Roubaix at 70/85. Just use this as a base for the minimum pressure you can run and adjust from there:
http://www.dorkypantsr.us/bike-tire-pre ... lator.html
Strava
misterq
by misterq
I weigh 61-62 kg
shimmeD
by shimmeD
Less is more.
bm0p700f
by bm0p700f
Why not just experiment. You don't need advise you just need try try different pressures to find what you like.
80-100psi, I weight 78kg-80kg
misterq
by misterq
thanks mainly just looking for a good baseline and where to begin. Now I am debating between making a few transition to tubulars all the time, training and racing.. Since need a second set of wide wheels for pit (or follow car) for racing. Cant imagine having to swap to my cheap 19 width rims in a race if flat haha
dj97223
by dj97223
At 68 kg, I've found that 80/85 in 25mm Roubaix on the wider Bora rims is the ideal feel for me, though I did get one pinch flat from a sharp rock.
