Campag 303 on SRAM Etap build
Jbarker1975
by Jbarker1975
Hi.
This has probably been answered before, but I am switching from Campy to a new Scott sram etap build. Someone here suggested I could keep my current 303 and cassette and run with the etap. Is that right and do I need to do anything additionally?
Thanks so much in advance.
James
grover
by grover
Are you asking if you can use Zipp 303 wheels with a campagnolo cassette with a sram red etap groupset? If so, yes, the 11 speed spacing between campag and sram is meant to be the same (or close enough that you don't notice a difference in shift quality).
glam2deaf
by glam2deaf
Go for gold, shouldn't be an issue at all.
Jbarker1975
by Jbarker1975
grover wrote:Are you asking if you can use Zipp 303 wheels with a campagnolo cassette with a sram red etap groupset? If so, yes, the 11 speed spacing between campag and sram is meant to be the same (or close enough that you don't notice a difference in shift quality).
Thanks. Really helpful!
Jbarker1975
by Jbarker1975
glam2deaf wrote:Go for gold, shouldn't be an issue at all.
Thanks !
