Mavic Road Tubeless
Tubeless tape might be a good thing given the corrosive nature of some sealants.
- cwdzoot
- Shop Owner
- Contact:
Got to test the Mavic UST yesterday and it's pretty impressive. Mounts easily with a floor pump.
https://www.facebook.com/glory.cycles/videos/1356421984433804/
Jonathan Vaughters was on the NBCSN coverage of today's tour stage and quite vocally highlighted that his Cannondale team will be riding Mavic's new road tubeless wheels in tomorrow's time trial stage. I didn't catch all of the discussion, but this was definitely talked about and he spent some time highlighting what they felt the advantages are to using road tubeless for them.
Something to keep an eye out for during the stage.
EvilEuro wrote:Jonathan Vaughters was on the NBCSN coverage of today's tour stage and quite vocally highlighted that his Cannondale team will be riding Mavic's new road tubeless wheels in tomorrow's time trial stage. I didn't catch all of the discussion, but this was definitely talked about and he spent some time highlighting what they felt the advantages are to using road tubeless for them.
Nothing really keeping pros on tubulars with removable valves from adding sealant...
High quality clinchers have less rolling resistance now. Not surprising. If you have a team car 100% of the time and don't have to worry about rolling downhill on a flat tire, why not?
I installed Zipp Tangente Speed RT25 tires on my ENVE SES 5.6 Disc wheels the other day. While there aren't Mavic Yksion tubeless tires officially, they're made by Hutchinson to pretty similar standards, so I'll make some initial comments.
1) Like Mavic, Zipp claims these tires mount easily with just the use of your hands. True! Even on my extremely wide 19/29mm wide rims, the job was very easy indeed.
2) The internal surface of the tires are super smooth compared to the current gold standard in tubeless road tires, the Schwalbe Pro Ones...
3) With how soft/pliable the tire is, the bead easily popped out of the center channel into the hooks with my high-pressure track pump without any special tricks.
4) Now some disappointment. Since the bead is smaller and very smooth, it didn't make the loud cracking noise I'm used to hearing when seating Pro Ones. Just the slightest pings at around 70psi. Because the initial seal isn't as tight as Pro Ones, the Zipp RT25s were hissing air everywhere, about 1psi every second until the tire reached 33psi where the hissing was no longer audible.
5) I tried two different tapes, Velocity Velotape (blue, thin, stretchy) and Stan's/Tesa. Both tapes did a poor job of sealing the tire without sealant. The Stan's tape caused a worse initial seal, I added sealant, inflated to 110psi and the tire was down to 30psi after 5 days. My Pro Ones would be more or less leakless after initial setup, maybe deflating down to 60psi in the same situation and after a few rides would lose maybe 3psi a day. The Velotape fairs better despite being thinner. With the velotape I add one layer of Stan's around the valve hole because when I use an awl to make a hole, it tears a little bit.
6) I added 40mL of Orange Seal to the Velotape set-up and I'm letting the wheel stew overnight. Hopefully it seals better within a couple days or it's back to Pro Ones and it's fat beads for me.
e: Just checked the set-up after a few hours and no major drop in pressure. Looking good.
Received the Mavic Cosmic Pro Carbon SL UST wheelset today.
Weight:
front wheel 0.66kg
rear wheel 0.80kg
measured with park tool ds-1 and rim strip still on
compared to my old Cosmic Pro Carbon SL C (weighted without rim strip)
front wheel 0.62kg
rear wheel 0.79kg
Weight:
front wheel 0.66kg
rear wheel 0.80kg
front wheel 0.62kg
rear wheel 0.79kg
- in the industry
- Contact:
the lack of seal has nothing to do with the cracking sound. lets dispell that. I have mounted tubeless tyres that dont make a loud cracking pop sound when they lock even though they lock in place securely without sealant.
Just because the pro one does it does not mean all tyres need to to get the same secure lock. The lack of sealing is because as you have noted there is a problem with the tyre/rim interface which maybe down to the small bead.
If the bead falls away from the rim with no air then i would go back to the pro one for all there faults they do mount the way a tubeless tyre should.
- Contact:
I have a pair of XM819 rims, which are tubeless UST and use the FORE cups to pair with 14-16 mm nipples. No holes in the rim bed, which makes them nice to use without tape. Obviously they were too nice, hence Mavic no longer make them... the new ones are conventionally drilled, with all the downsides of having to tape the rim bet etc...
Such a shame the FORE idea didn't catch for handbuilts, I love being able to rebuild the wheel without even having to remove a tyre
DDX wrote:Received the Mavic Cosmic Pro Carbon SL UST wheelset today.
Weight:
front wheel 0.66kg
rear wheel 0.80kg
front wheel 0.62kg
rear wheel 0.79kg
Received mine today - weighed as above = 1555g total for both wheels[emoji848]
