Powerway R13 hub set stats 15.75/37.45 41% tension L/Rt w Jpegs
- WinterRider
Recently purchased for 'X' wheelset .. experimental. Stats posted marketing ad musta not made the
trip per translation.. wayyyy off. So .. given I can NOT find anything on the Powerway site.. this is what I measure at. SINCE... Powerway sent drawing.
Litespeed 2000 Appalachian 61 cm
Litespeed 1998 Blue Ridge 61cm
Fitness rider.. 1 yr from seven decades age.
That is my story and I'm stick'n to it.
15mm center to right is awful. Best config might be radial or 1X heads in on right and crossed pattern on left, but I wouldn't build wheels with those hubs.
Bitex from bikehubstore would be a better budget option.
- WinterRider
ergott wrote:15 (mistake-- 17mm is correct.. WRider error)mm center to right is awful. Best config might be radial or 1X heads in on right and crossed pattern on left, but I wouldn't build wheels with those hubs.
I can find no way to access Powerway stats, hub internal schematics et al anywhere-- which includes their site. But I knew before plunking down the coins. Yet I do not employ 11 speeds... do not rock the bike climbing so I think clearance is a non issue for me (?).
To reiterate .. this hub purchase for a 'X' project 12-8 lacing. I'm riding this configuration in a 560 gr rim with Sapim Strong laced all radial both ends... rims/spokes producing a very stiff wheel. Next version very light .. testing the limits per my wt and riding style.
Image shows 17 rt.. w spacer gives room for 10 speed spacing. Image hard to see clearly.. it's what it is.
I can't see that clearly, but if it's 17mm that's obviously much better.
- WinterRider
ergott wrote:I can't see that clearly, but if it's 17mm that's obviously much better.
Granted pic quality isn't clear .... ruler markings & hub both blk. These measurements give 105/72.5 balance R/L on 12-8 lacing with this hub... rim being Kinlin 200 which I limit to 105 kgf. Using a rim at 120 kgf rt would yield 82+ left 12-8.
So lopping off 4 left spokes from 24H down to 20---> 12-8 increases left tension from 55+ to 82+kgf over 12/12 24H conventional lacing using 120 kgf max rt.. the reason for my interest.
Makes one wonder who/what designed the Powerway hubs...........
Either way, 20 spokes isn't a lot for a rear wheel. I wouldn't ride it at my 74kg.
- WinterRider
ergott wrote:Either way, 20 spokes isn't a lot for a rear wheel. I wouldn't ride it at my 74kg.
I can understand that. I'm around 83 k's.. we're going to see.
I've seen rear 20's being used for a guy well (well..) over 3 bills... albeit bladed aluminum of substantial size/thickness. I do not follow pro cycling but one sees pics of G3 21's in use for elite riders. I've "straightened" a few rims .. one mangled in a wreck headed towards a figure 8 shape (learning/recreational pursuit) which impressed me the strength of the alloy hoop. And being a fitness rider who does no climbing (no real grades these parts) that test mute. Tires and the pressure their run at (mine 28's at 80 psi rear) mean much.
If I could have found an alloy light weight G3 drilling that was my preference. But just an itch to scratch...
