It is currently Fri Oct 20, 2017 2:52 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
 Post subject: lightweight rim tape?
PostPosted: Sat Apr 22, 2017 6:42 pm
i just removed the thick yellow plastic vinyl rim tape from my kinlin 19mm wheelset. they weigh 22g each.
is there a lighter option for rim tape? will electical tape work by just covering up the holes? or stans?
PostPosted: Sat Apr 22, 2017 7:04 pm
Blue Schwalbe tubeless tape is a lot lighter, not too pricy and reliable. Electrical tape is not strong enough. You could find some textured tape from 3M, it would do the tric.
Canyon Ultimate CF SLX 2013
Scott Addict Orica Greenedge
Canyon Endurace CF SLX
PostPosted: Sat Apr 22, 2017 7:08 pm
Or Stan's is also an option
PostPosted: Sat Apr 22, 2017 7:32 pm
why cover the entire rim just for the holes?
check out "Veloplugs"
PostPosted: Sat Apr 22, 2017 7:38 pm
Thanks for the suggestions.. gonna go to LBS and see if I can find them.
PostPosted: Sat Apr 22, 2017 7:40 pm
I second veloplugs, I've used them in about 8 wheel sets over the last 5 years and never had an issue with them and they're about 5-6g per wheel.
PostPosted: Sat Apr 22, 2017 7:53 pm
+3 on Veloplugs. Good to go!
Just be sure to get the "right" size.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Sat Apr 22, 2017 7:57 pm
Veloplugs have their own limitations. They do not fit all rim holes. Red ones can be too lose, the yellow ones will not sit in properly.
I used them for quite short period of time (Archetype rims). After having spectacular failure, where one of the plugs was melted down and pusched inside the rim, I thanked them for good.
Stan tape, cheaper alternatives: kapton tape or Tesa 4289 (very similar to Stans).
Sent from my SM-T800 using Tapatalk
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Sat Apr 22, 2017 8:40 pm
The cool kids are using Scotch Film Strapping Tape 8898 Ivory, 24 mm x 55 m
There's sometimes a buggy.
One.
PostPosted: Sat Apr 22, 2017 9:23 pm
Tubeless tyre tape s light. Var tape is lighter than stans.
www.thecycleclinic.co.uk
PostPosted: Sat Apr 22, 2017 9:52 pm
+1 on the scotch tape.
I'm curious if veloplugs plus skinny strippers would be good enough for road tubeless.
PostPosted: Sun Apr 23, 2017 12:30 am
just came back from LBS and found some Stan's no tube rim tape. but they only have 21mm, whereas my kinlin 19mm profile rims have 16mm internal width. :(
took a sharpie.. drew a fine line around and took a knife and cut around it. now it's perfect 16mm. :)
PostPosted: Sun May 07, 2017 10:28 pm
Is there an online supplier for rolls of that?
PostPosted: Sun May 07, 2017 10:47 pm
A little known outfit - Amazon
One.
PostPosted: Sun May 07, 2017 10:52 pm
Yeah... min order box of 9 rolls is what I found, lol. I don't need half a kilometre of the stuff!
There are no new unread posts for this topic. Attachment(s) Rim tape check
possibleweenie
7
411
Thu Aug 24, 2017 11:56 am
Marin View the latest post
There are no new unread posts for this topic. Tape instead of hoods?
whydobearsxplod
13
1116
Fri Sep 29, 2017 4:46 pm
whydobearsxplod View the latest post
There are no new unread posts for this topic. Suggestions for finishing bar tape ?
wobbly
22
1555
Sat Jul 15, 2017 6:11 am
Nefarious86 View the latest post
There are no new unread posts for this topic. Favorite bar tape for aerobars
Kurets
Sat Jul 08, 2017 11:34 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Attachment(s) Silva chrome bar tape
ksy8828
Tue May 09, 2017 2:51 pm
Stolichnaya View the latest post
Users browsing this forum: Google Adsense [Bot], loudtiger, steelbikerider and 5 guests
