23 vs 25 tyre
Marin
by Marin
GP4000s are almost comically wide, 25s are 28mm and 28s are 31mm and will fit almost no bike with caliper brakes.
Do yourself a favor and get a cotton tire - Veloflex or Vittoria, the ride quality is just sooo much better, and they're fast enough too.
marshalus
by marshalus
Marin wrote:GP4000s are almost comically wide, 25s are 28mm and 28s are 31mm and will fit almost no bike with caliper brakes.
Which Veloflex or Vittoria clincher do you recommend? What about their size 25 is 25?
The good thing about GP4000s is millage. I put over 17000 km on my last set? How is it compared to Veloflex or Vittoria?
DavidMLee
by DavidMLee
Only two mms but it actually is over 8 per cent increase in tire width.
It definitely makes a difference especially on a long ride.
Legend HT 9.5 RED 22
Colnago C60 Super Record
S-Works Tarmac 2016 eTap
S-Works Tarmac 2015 DA
Cervelo R3 2015 UT
Cervelo S2 2014 UT
Spesh Venge Elite 105
Marin
by Marin
marshalus wrote:Which Veloflex or Vittoria clincher do you recommend? What about their size 25 is 25?
Vittoria Corsa G+ 23s will measure 25mm, 25s are 27mm.
Veloflex Master/Corsa 23s and 25s are true to size i.e. 2mm narrower than Vittorias. I have multiple sets of both and think both are excellent. Veloflex are much lighter and a quite a bit cheaper.
fogman
by fogman
Is Veloflex still not recommending use of their tires on carbon clincher rims?
I have found that the Vredestein Fortezza Senso All Weather 25mm clinchers to measure the narrowest on 17c internal width rims. Mine measure 26mm on my Bora One 35 clinchers. They did not score well on the rolling resistance test though.
It's all downhill from here, except for the uphills.
Calnago
by Calnago
fogman wrote:Is Veloflex still not recommending use of their tires on carbon rims?
I think so. I don't use the Veloflex clinchers, but I've seen some getting torn up with the Vision carbon rims that a friend sells. Regardless of what clinchers you're using, it's a good idea to check to see how sharp the inside of the bead edge is on your carbon rims. Some are smoother than others. Continental has a warning about that as well. Yet the Conti 4000Sii's have not seemed to suffer the same fate on the same wheels.
