It is currently Wed Jan 17, 2018 2:04 pm
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Fri Mar 17, 2017 10:19 pm
Evening guys,
I've got a rear Corima Aero+ carbon tubular wheel which is giving me some grief. I stripped the hub some time ago to replace the bearings, but for whatever reason it got left for some time and when I've got back round to sorting it I can't remember how it came apart (!).
Basically, when the freehub is installed, and I try to screw the cones in on either end of the axel, as soon as there is a hint of tension, the freehub tightens up. Its like they're pressing right on the rubber bearing seal and tightening it all up. Could someone familiar with these wheels shed some light on this? I'm not sure if I'm missing a washer or something. I've checked the exploded view and it all looks there.....
Some pics: https://drive.google.com/open?id=0ByEBC ... F9xLVRieUk
Thanks
PostPosted: Mon Mar 20, 2017 2:39 pm
I'm guessing you are missing the slide on sleeve spacer between the freehub and the outside bearing in the hub?
PostPosted: Tue Mar 21, 2017 11:20 pm
Thanks for that. It was missing a small sleeve between the freehub and hub like you said. Also, I had a few end cones for the non drive side which are very slightly different. The one I had was pressing against the actual bearing seal and hence stiffening it up. I swapped it out and they tightened up fine. Headache over!
There are no new unread posts for this topic. Aero bars on non aero race bike
gurk700
19
4474
Wed Jan 03, 2018 7:29 pm
Chans1ee View the latest post
There are no new unread posts for this topic. Corima mcc s + 47 How much is usually in your country?
in Everything wheels
shineplus
Thu Jun 01, 2017 7:07 pm
sungod View the latest post
There are no new unread posts for this topic. New Corima rims
commfire
Mon Apr 03, 2017 5:07 am
sethjs View the latest post
There are no new unread posts for this topic. Hutchinson rt1 by Corima
bogdanescu
Tue Jul 25, 2017 7:16 pm
bogdanescu View the latest post
There are no new unread posts for this topic. Wheels for C60 - Hyperon or Corima?
prglewis
27
2700
Sat May 20, 2017 7:40 pm
prglewis View the latest post
Users browsing this forum: Baidu [Spider] and 8 guests
cron
