bikeradar tests the best aero wheels for tt's
spartan
by spartan
https://www.youtube.com/watch?v=h0BH3wXzhrI
impressed with bikeradar performing more analytical tests in the lab.
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
AZR3
by AZR3
Interesting to see the CLX64s so low, I figured they'd be at least mid pack but the test makes me happy that I bought some HED Jet 6+/9+ a few years ago and they're still fast as hell (although I wish I had those black brake tracks :cry: )
Marin
by Marin
Don't have the nerve to watch a 12 min video, but in the table at the end they don't show 0° yaw numbers?
I don't ride my bike at 5° or 12.5° usually as I prefer riding straight ahead, so this is a joke.
It's time someone admitted that all the wheel aero magic isn't worth much when going fast in low wind, and that wide wheels and tires will slow you down most of the time.
Mackers
by Mackers
And have the cheap narrow chinese wheel win?
That'll go down well with the advertisers :)
jlaitinen
by jlaitinen
Marin wrote:Don't have the nerve to watch a 12 min video, but in the table at the end they don't show 0° yaw numbers?
I would like to live where you live, a paradise where there is no wind.
guyc
by guyc
Marin wrote:wide wheels and tires will slow you down most of the time.
Uh?
Marin
by Marin
guyc wrote:Uh?
Uh-huh.
When you go in a straight line and there isn't a strong side wind, a narrow tire and rim has a smaller frontal area and thus lower aerodynamic resistance. It's so logical that it seems almost strange in the current marketing hype.
If you look at the popular yaw charts, you will see them overlap in the middle, meaning that there isn't a lot of difference between wheels when the wind comes from the front.
There is very little actual field yaw data available, and much of it comes from manufacturers who have an interest in presenting high-yaw (i.e. sidewind) conditions because only these will help them sell wide wheels.
guyc
by guyc
And rolling resistance?
Marin
by Marin
Wide tires are harder at identical pressures, and if you lower pressure to achieve equal ride comfort, the advantage in rolling resistance is quite small.
Additionally, rolling resistance rises linearly, while air resistance rises with the square of speed, so if you go fast, aerodynamics dominate rolling resistance.
That's why you won't see time trialists or track riders on wide tires.
LeDuke
by LeDuke
Marin wrote:Wide tires are harder at identical pressures, and if you lower pressure to achieve equal ride comfort, the advantage in rolling resistance is quite small.
Except Tony Martin, riding 25mm clinchers.
So much for that theory, eh?
Sent from my XT1585 using Tapatalk
Marin
by Marin
LeDuke wrote:Sent from my XT1585 using Tapatalk
Everyone is running 25mm now, but not wider. I doubt we'll see anyone adopting 28+ for the road, even though rim manufacturers are starting to push 21c rims.
However, IIRC Tony Martin was running staggered clinchers in 24mm / 26mm. The S-Work Turbos don't come in 25.
LeDuke
by LeDuke
The 24s measure out at 25mm on many wheels.
Point being, 19s, 20s and 21s used to be the name of the game for TTs. Many tires aren't even made in 21mm widths anymore.
Marin
by Marin
It's a trend, like bikes getting heavier every year.
It's very important for manufacturers to make or label components as incompatible so you e.g. have to buy not only wider tires because they "roll faster" but also wider rims to make the sidewalls "less of a bulb shape" etc.
Give me a good reason for the bikeradar test not even measuring at 0° yaw :)
LeDuke
by LeDuke
Marin wrote:It's a trend, like bikes getting heavier every year.
Because if you have ANY wind at all, aside from dead on headwind or tailwind, you'll see angles >0°.
Imagine a scenario where you are riding in the Midwestern US. All the roads there are on a grid, aligned more or less perfectly on the cardinal directions, and in 1mi x 1mi squares. If you are riding due west, how often to you think you'd encounter a wind that is coming from 270°? And how often would it be anywhere from 180-360°? Or, 225-315°?
Yaw angles of 5-20 degrees are measured because they are more realistic conditions than 0°. Still air or a dead on headwind are a statistical anomaly.
NovemberDave
by NovemberDave
LeDuke wrote:
Marin wrote:Yaw angles of 5-20 degrees are measured because they are more realistic conditions than 0°. Still air or a dead on headwind are a statistical anomaly.
http://www.slowtwitch.com/images/trek/TK13_SC_Whitepaper_final.pdf
http://flocycling.com/aero.php
You are of course welcome to be skeptical of these data sets as maybe they're tailored to fit an agenda. Of course wider angles happen, but I think it's an error to call them prevalent.
I had a unique opportunity to ride with the top US Ironman athlete days before he headed to Specialized's Win Tunnel to do his aero testing in prep for the 2014 season. Ironman triathletes are maybe the people most concerned about aerodynamics out of all cyclists. I asked him the direct question of what sweep range he planned to test, to which he replied that he'd only test -10* through +10*. Angles outside of 10* aren't seen in enough concentration to be concerned with them. By which I mean that they happen, but the clusters of incidence happen at low angles. The athlete in question had free access to the tunnel as he was sponsored by Specialized, so this wasn't a question of resource constraint.
Take that for what it's worth.
