Who is running latex tubes on carbon clinchers?
RJKflyer
by RJKflyer
Am considering doing so, and yes am fully aware of the official guidance to not do so.
Rim brakes and probably Campy Bora 35.
However, the concern emanates from heat and heat comes from distance done at weight and gradient etc...
I'm 130lbs and my descending is pretty much limited to a couple of miles at 5% max probably no more than 3-4 times reasonably evenly-spaced throughout 30-40 miles. Plus maybe an occasional few tenths of a mile at 20%.
Thoughts? Please - only if you are doing it/have done it...!
duende
by duende
Same situation. I'm close to 200lbs though. Been running latex in my Bora 35's in the Bay Area. I've done plenty of descending off some rather steep hills/mountains, but I've only had the wheels a couple months. So far so good, but definitely am concerned about it.
AZR3
by AZR3
I have about 10k miles on my RaceRim CCs with Vittoria latex tubes with no issues. I've done plenty of climbing and descending with some heavy/emergency braking, all without any heat related issues.
PrimO
by PrimO
I'm using Michelin latex tubes in my Fulcrum Quattro Carbons with no problems in the last 12 months. I have checked the wheels for heat build up at the bottom of a few descents shortly after I fitted the latex tubes and while they were warm, they weren't anywhere near where they'd heat up or burst the tubes.
I also tested them on a long 2km straight descent where I had reached just over 70kms and dragged the brakes for approx. 400m just to see how hot they got. They were admittedly hot but I could hold my fingers on the brake track without them getting burned so it wasn't going to do the tubes any harm.
RJKflyer
by RJKflyer
Confirms what I suspected, but real world feedback much appreciated.
So far, so good...
dereksmalls
by dereksmalls
Running Vredestein latex (becoming increasingly harder to find though) with old style Enve 45 clinchers since I got them in like 2012 I think?. Had no issues with them over heating or blowing out at all on long dragging decents on even short hard stress braking. and I don't think it's really an issue anymore these days to be honest. Rim technology has come a way since this was first an issue. Oh and I'm 70kg
guyc
by guyc
Yes. Vittoria tubes on Cosmic Pro Carbon SL's but I live in an area with no serious hills. I'm 86kg.
golfsierra
by golfsierra
I run Boyd 44mm CCs with Michellin Latex tubes
73kg and don't do any serious descending, but so far, so good.
Johnny Rad
by Johnny Rad
After >10K mi, I've got the same pos experience with latex and clinchers. I don't stress it anymore.
Even when I warped a rear wheel years ago descending behind a car (totally my fault) down a steep descent, the latex tube inside didn't pop.
Rider weight and grade is important to the formula, but so is NOT dragging your brakes. It was steep going up, so enjoy the fast descent!
Juanmoretime
Administrator
by Juanmoretime
I've been riding carbon clinchers with latex tubes for over 5 years. No issues. I did go from Michelin latex to Vittoria since the Michelins always after a long time would fail by the valve stem. I had zero flats last year on the Vittoria's in every 6,000 miles of riding.
RESIDENT GRUMPY OLD MAN.
RJKflyer
by RJKflyer
Thanks all.
Looks like you are all going to cost me some money...!
Marin
by Marin
The most commont source of failing latex tubes is faulty installation.
You should be able to install the tire without levers, and you need to be very careful to not catch the tube under the bead by checking the bead visually after the tire is mounted.
A pinched tube will explode after a *random* duration! Maybe during inflation, mabye in the night, maybe during the next ride. The telltale sign is a long tear. This happens on clinchers regarless of whether they are carbon or alu.
When istalled correctly, latex tubes will suffer fewer snakebite punctures, and when pierced by glass or thorns will leak air quite slowly, so they are actually safer than butyl.
Unlike with tubulars slipping on hot rims, I haven't heard any confirmed temperature related failures from latex. All incidents reportes as such were the long tear type associated with sloppy installation.
RJKflyer
by RJKflyer
Marin wrote:The most commont source of failing latex tubes is faulty installation.
Quite. Have run latex tubes without a single failure on my current wheels and/but of course you need to be careful during installation. But then we should be with any fitment...
Unbrokenchain
by Unbrokenchain
Do use talc on latex tubes when installing?
RJKflyer
by RJKflyer
Unbrokenchain wrote:Do use talc on latex tubes when installing?
yes, always. Anything to help prevent the (thin) tube snagging on assembly and/or later on.
