It is currently Sat Dec 16, 2017 8:53 am
Post new topic  Reply to topic  [ 130 posts ]  Go to page 1 2 3 4 59 Next
 Post subject: New Mavic Open Pro
PostPosted: Thu Mar 09, 2017 12:24 am
Saw these pop up in my Instagram feed, but there is little info about the rim available so far. Notwithstanding, they look interesting and will be good to compare to the specs of the current favoured alloy rims.
https://www.instagram.com/p/BRZSCQdhjj5/
https://www.instagram.com/p/BRZSOO6B3ie/
Sent from my EVA-L09 using Tapatalk
 Post subject: Re: New Mavic Open Pro
PostPosted: Thu Mar 09, 2017 12:30 am
It looks like a ksyrium rim.
Colnago C59
PostPosted: Thu Mar 09, 2017 12:53 am
If theres a 20/24, ~25mm wide, non-eyelet version, my cock will be up.
PostPosted: Thu Mar 09, 2017 1:16 am
Even if it's only available in 32/36, 17mm internal, and lighter than 415g it'll be a great rim. Would be a great rim for traveling/training - anything between touring and target races IMO.
@dudemanppl, does this get you up? https://www.dtswiss.com/Components/Rims-Road/RR-411
I write the weightweenies blog, hope you like it :)
My SwiftCarbon Ultravox
My Velocite Selene
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
PostPosted: Thu Mar 09, 2017 1:40 am
Nope, cause it doesn't have a black brake track. :)
17.5mm internal, <435g for MOP Exalith.
PostPosted: Thu Mar 09, 2017 1:41 am
eyelet rims in 2017.. no thanks
Skunkworks Bikes
PostPosted: Thu Mar 09, 2017 5:14 am
Not even if you're trying to go for a 'classic' look (not referring to the MOP, but to something like a TB14)?
Sure modern rims don't need eyelets but it seems a bit silly to write a rim off because it has them...
My Velocite Selene
PostPosted: Thu Mar 09, 2017 7:31 am
Mah-veek is so desperate for street cred they'd smoke fat rocks with Cracky Joe if the mofo rode a bika and had 50K Insta followers.
Those rims are going to look tite on the track bike I haven't ridden since 2008.
PostPosted: Thu Mar 09, 2017 7:56 am
istigatrice
they have eyelets for one of 2 reasons...
nostalgia or cause they are still using the low grade 1990s 6000 series alloy they originals are made of so yeah...
neither is a good reason to have an eyelet rim in 2017..
these won't hit the ground for quite a while and the 'whale' profile may attract lawyers from SRAM
i've reached out to some one building a pair of proto rims for NAHBS about the tension limits.. that'll answer my questions pretty quickly..
nice of you to say hello in Adelaide.. i'm actually pretty nice in person :D
Skunkworks Bikes
PostPosted: Thu Mar 09, 2017 4:35 pm
Double eyelets were kind of nice back in the day-never had to shake nipples out of the rim cavity while building.
PostPosted: Thu Mar 09, 2017 7:28 pm
Online
Even though it's the same shape Mavic have been using for years and is nothing like the Zipp scallops?
Maybe, doubt it though :wink:
PostPosted: Fri Mar 10, 2017 12:06 am
@Sugarkane, fair enough, but if it's for nostalgia I wouldn't mind so much, the weight of 435g is competitive IMO. Keep us posted about the tension please!
My Velocite Selene
PostPosted: Fri Mar 10, 2017 12:39 am
Well i hope mavic do bring a modern rim into production.
www.thecycleclinic.co.uk
PostPosted: Fri Mar 10, 2017 1:43 am
Exciting - if it's anything like my Ksyrium SLRs, should build a pretty solid wheel.
The thought of these rims with some nice Tune hubs =)
PostPosted: Fri Mar 10, 2017 7:08 am
Well I for one am looking forward to this rim being available. I've been pestering Mavic GB as long as Ksyrium/R-SYS/Cosmic SLR wheels have been around for an Exalith rim. Finally it looks as if it will be a reality. They aren't going to be cheap though, With stock OP rims going for nigh on £50 I doubt we'll see change out of £100 per rim.
There are no new unread posts for this topic. Mavic Qr Titanium + Mavic Tubulars + Mavic Carbon Brake Pads - NEW
elfuinha
Thu Dec 14, 2017 1:02 pm
elfuinha View the latest post
elfuinha
Mon Nov 27, 2017 10:40 am
There are no new unread posts for this topic. New to me: Open Cycle O-1.0
Sacke
Wed Aug 16, 2017 9:14 am
Sacke View the latest post
There are no new unread posts for this topic. open tubulars
bennybikes
Fri Nov 03, 2017 4:36 am
vanillaflyweight View the latest post
There are no new unread posts for this topic. PSA: Wiggle Vittoria Open Pave CG - $33
Pschnei3
Tue Sep 12, 2017 5:33 pm
Pschnei3 View the latest post
Users browsing this forum: dim, siim and 6 guests
