Schmolke TLO 30 Tubulars...in hand!
Broid
by Broid
Schmolke TLO 30 tubulars (20/24) from the super nice folks at Fairwheel. 1040g on my scale. I'll get them glued up this week and will post a ride report asap...
Brian
http://www.pbase.com/onlyamoment/image/164596668
http://www.pbase.com/onlyamoment/image/164596670
AZR3
by AZR3
Looks good, what hubs did you choose?
Broid
by Broid
AZR3 wrote:Looks good, what hubs did you choose?
I was somewhat limited on my choice for a variety of different reasons, but went with Tune, which is the hub that Starbike is building them with...
mai
by mai
almost pulled the triggers on a pair myself, but was a bit worried about the braking
* enve 6.7s - terrible
* shimano c75 - so-so
* ax lightness s55t/u24 - excellent
how well do these schmolke tlo rims brake?
mai
by mai
Broid
by Broid
mai wrote:almost pulled the triggers on a pair myself, but was a bit worried about the braking
I'll let you know. I'll get tires glued up this week and ride next. I'll post a report. I'm curious about that myself...
qorwlch
by qorwlch
nice rim....
weight is 400g??
:x
Broid
by Broid
qorwlch wrote:nice rim....
weight is 400g??
585g for the rear wheel and 455g for the front...1040g for the set
Similar weight to LW Gipfelsturm. I'd like to see a comparative test someday.
liketoride
by liketoride
did you get a chance to ride the wheels yet? looking for a ride report on the wheel and a review on the braking surface please. Thank you
bm0p700f
by bm0p700f
The problem i have with those schmolke and all the others wheelsets mentioned i built myself a 1020g set with carbon ti hub and 38mm deep tubular rims. Braking is as good as alloy rims ( i stop just as quickly) and cost well a hell of alot less than what schmolke are charging. So how do i mange it when enve can't.
It would be interesting though to know more about them.
Nejmann
by Nejmann
bm0p700f wrote:The problem i have with those schmolke and all the others wheelsets mentioned i built myself a 1020g set with carbon ti hub and 38mm deep tubular rims. Braking is as good as alloy rims ( i stop just as quickly) and cost well a hell of alot less than what schmolke are charging. So how do i mange it when enve can't.
What rims and hubs did you use? Sounds nice with the breaking.
F45
by F45
Can the Tune front hub not handle radial lacing?
mrlobber
by mrlobber
So what's the weight of TLO30 rims?
Broid
by Broid
First ride, short, about 32 miles and a couple thousand feet of climbing, so good descending too. Again, 1040g (TLO 30 tubular, Veloflex carbon tires) for the wheelset (Tune hubs) put together by the good folks at Fairwheel. These are on my Parlee Altum R, Campy EPS, EE Cycleworks brakes, Swiss Stop Black Prince pads.
As you might expect, acceleration is exciting. There is quite a bit of road feel and I'm not sure if that is the tire or the rim, more riding needed. This ride was very windy, so lots of cross winds, but the wheels didn't care. No cross wind issues. Downhill speeds never topped 35mph, but the wheels felt very stable and cornering was great. The biggest and nicest surprise was the braking, very solid, no pulsing, smooth and steady with no squealing. They look bitchin' and I'm very impressed so far. More after my next ride. I ran the tires at 110 and 100 psi and will try less next time. Thinking about ordering the TLO 45 clinchers...
