It is currently Sun Dec 17, 2017 8:52 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Sun Nov 13, 2016 2:56 pm
I just finished a Powertap GS build. The NDS tension is very low, so I would recommend go with big spokes and stiff rim at your weight.
Kinlin XR31T is a very good suggestion IMO.
NOTE: I had to cut 2mm off my spokes based on the Powertap chart. And I heard it happened to a few other builders too.
Make shure you get the lenght right.
Louis :)
PostPosted: Mon Nov 14, 2016 5:13 am
Who likes / dislikes the idea of Sapim Laser spokes laced to a GS straight pull hub and Reynolds Attack clincher rim? Are they too dainty?
I think an Aero spoke will be more fiddly for truing, so I'm looking at round spokes. Am I mistaken?
I'm 73-74kgs. My Reynolds Attacks use straight pull spokes front and rear, as built by the factory.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Tue Nov 15, 2016 12:52 am
You'd have a MUCH easier time with bladed spokes. I just flat out refuse to build straight pull hubs with round spokes. Get bladed spokes and a spoke holder and you're way better off. Keeping straight pull round spokes from spinning is a be-yotch, and then compound that with the windup you get with Lasers. Just do blades.
http://www.novemberbicycles.com
PostPosted: Tue Nov 15, 2016 5:55 am
Thx for the advice. Appreciate it.
PostPosted: Tue Nov 15, 2016 7:44 am
ergott wrote:
I wouldn't do that build. The hub doesn't build up to a very stiff wheel...
You wrote that the hub does not build up to a very stiff wheel: is this just the Powertap GS rear hub or is it common for all DT Swiss straight pull hubs? I am asking because I have been planning another wheel build, using DT Swiss hubs.
PostPosted: Tue Nov 15, 2016 3:56 pm
The DT Swiss rear straight pull hubs also have poor geometry. The fronts are okay and I've used them. I flat out refuse to use the straight pull rears, especially when their flanged counterparts are better (albeit not ideal).
www.ergottwheels.com
PostPosted: Thu Dec 15, 2016 9:20 pm
My new wheel arrived and I've been for my first ride! In the end I went for a Kinlin XR31t, 24h offset with Sapim CX-rays. Very happy. I got it made by DCR wheels in the UK, who I can recommend too.
958g with 10 speed spacer, stans tape, and without skewer (sorry about the crap photo).
Thanks everyone for the help.
PostPosted: Sat Dec 17, 2016 1:28 pm
To Powertap GS hub,any heavy rims is the stone of Sisyphus, you need both eccentric rims and heavy spokes,the best choice is carbon eccentric rims.
PostPosted: Mon Dec 19, 2016 3:13 am
Good insight there. I agree, except that the front straight-pull flanges on the disc variant are less than ideal, being too close together (i.e. short center-to-flange measurements).
PostPosted: Mon Dec 19, 2016 3:14 am
Louis :)
Powertap says the spoke lengths should be the same for both sides of this hub. Were they?
PostPosted: Mon Dec 19, 2016 7:14 am
I did not have any issues with the spoke lengths. I used the same length both on DS and NDS and the length was calculated using the formula from the spoke length chart. I used Sapim CX Ray spokes.
PostPosted: Mon Dec 19, 2016 4:49 pm
Louis :)
Yes, they were.
I had to cut all of them.
Louis :)
There are no new unread posts for this topic. Wheel set recommendations and suppliers for a new bike build
in Everything wheels
apctjb
12
675
Thu Nov 09, 2017 10:05 am
kidrob View the latest post
There are no new unread posts for this topic. Durability/stiffness of Powertap G3 build - 24H vs. 28H
savechief
Sun May 28, 2017 8:44 am
DutchMountains View the latest post
There are no new unread posts for this topic. Schwalbe Pro One + Normal Stan's Sealant
MagicShite
7
222
Fri Dec 15, 2017 3:15 pm
ms6073 View the latest post
There are no new unread posts for this topic. Stan's sealant in tubes for puncture sealing?
WinterRider
7
557
Thu Aug 17, 2017 1:52 pm
There are no new unread posts for this topic. Upgrade from wheels with Gipiemme H32 to WR Compositi T33-W ALPHA
3Pio
Tue Apr 18, 2017 10:38 am
3Pio View the latest post
Users browsing this forum: Hapsmo911 and 6 guests
