50mm Aero Wheel Disappointment
Lugan
by Lugan
hlvd wrote:
Lugan wrote:My Bora One 50 clinchers with 4000S 23c tires climb like scalded cats. The descend, roll on the flat, and sprint the same too. Might be better stiffness and possibly even higher bearing quality.
What tyre pressure do you use?
I weight 180# and run them 80-90 F-R. The inside width of the rims is 17mm and the tires fully inflated measure 25mm wide. They're super stable in hard corners set up like this and comfortable enough for long rides.
