by dunMisk on Sun Aug 21, 2016 8:53 am
Ok, so we actually have two questions now. C24 vs Assault and 'What makes a great wheel?'. Here's my view:
A theoretical great wheel:
- As light as possible (1450-isch is light enough for me)
- As stiff as say a 60mm or higher carbon rimmed wheel (good bracing angle)
- Braking as good as alu braking, in dry and wet
- A hub with big enough bearings for smooth rolling and prolonged life
- Easy replaceable spokes
- The sexy black look + subdued graphics (I like the Easton/Roval type of graphics)
- As little as possible reaction to side wind
- Maximum aero*
- Clincher for practicallity
- A wide rim has a better rolling resistance and corners better
You could personally score each of these factors and decide what you think is important. A couple of aspects to work with:
- The difference between a mid-wheel vs a >60mm only differs about 4 watts. (Tour magazine, 8/2016, 19 aero wheelsets tested)
- A light rim is more important then a light hub
- I feel the difference between a small and a wide rim, and really prefer a wide rim
- I forfeit the black look for the alu-braking power.
- I tried tubulars, and although I never flatted, I couldn't shake the feeling of what if...
So for me, a wide rim, medium height, aluminium, which is as strong as possible and also as light as possible is for me the best possibl wheel.
Now to the C24 vs Assault discussion. I have the C24's. I have ridden 45mm carbon clinchers (not the reynolds):
- I think the C24's are to narrow. They are build very well. Look very good, but to narrow. I'm going to sell them.
- The Reynolds: In the tour mag article, they deformed under heavy breaking (as did several chinese rims and older DT-swiss rims, new were ok). If you want to go carbon, go with Zipp, newer DT-swiss or Campagnolo/fulcrum. For price/performance-wise, the fulcrum Quattro were really good.
*Aero on a wheelset is only a small part of your general aero profile. First, get a aero position, good fitting jersey (you need more then one), aero helmet, aero frameset and then a aero wheelset.**
**Aero only becomes important if you have your bike-fit, training-plan and food sorted out. A good bike-fit can instantly generate +10 watts. Your training-plan should incorporate twice a week interval-training. Your food intake should focus on enough proteine for recovery and suffient carb-intake pre-ride for enough muscle cel glycogen
Now I stop, sorry for overkill.
