Meilenstein clinchers/tubs
- in the industry
- Contact:
kgt I have punctured a gatorskin tub. I did nothing wrong I just rode down a road in a british winter. It is called flint + rain it cuts through everything even gatorskins.
Tubs though are better than clinchers. Inner tubes only belong in tubulars it should be a law.
It amazes me why you head scratced for week. Welcome to your new tub addiction. You will have many tubs soon, all prepped and ready to go.
I have a set of wheels with gatorskin tubs ready for winter and several spare tubs ready as spares as you never know. This is your future enjoy it.
I have to say, I'd had nearly 3 years of riding tubs....it just seemed I was puncturing every other ride, pit stop very rarely worked.
I hated carrying a spare tub (this is weightweenies remember)
But agree loved the ride quality/looks of tubulars.
I was 50/50 to get clincher over tubs but what tilted slightly in favour of tubs was the durability of the rim design over carbon clinchers, especially with lightweight rims not being a replaceable item.
Hopefully I'll have a better run this time.
Cheers for all the advice and comments.
Steve
Steve
that is called bad luck.
- iliedanila
Because latex tubes are more sensitive to heat build up from the rim
Sent from my SM-G928F using Tapatalk
Latex is not ok on an aluminum or carbon clincher, on mountainous or flat terrain. Latex only belongs in a tubular rim. That's why Conti doesn't sell a latex tube separately but they sell tubular tires with latex tubes.
- Moderator
So in my clincher Disc/808 wheels that I TT on and brake for approximately 2 x 10s in 25km it's not safe? Or how about my disc brake clincer wheels?
Using Tapatalk
kgt wrote:If punctures is your problem then just buy a pair of Continental Gatorskins. You will never puncture unless you do something completely wrong. Not the nicest tire of course but a 25mm one at 90psi would feel ok.
I cannot see though how a clincher tire would puncture less. The opposite is usually the case.
There's got to be some sort of rule about installing Gatorskins on LWs. I will very much disagree that 25s (which look huge on the Meilensteins) at 90psi would feel OK. They'd feel better than at 110psi, but they'll still feel terrible.
In terms of punctures on clinchers, it's not the frequency of the punctures that typically concern people, it's the process of replacing the puncture.
dre_lo82 wrote:There's got to be some sort of rule about installing Gatorskins on LWs. I will very much disagree that 25s (which look huge on the Meilensteins) at 90psi would feel OK. They'd feel better than at 110psi, but they'll still feel terrible.
You have to strech them in a tubular rim and then it's a piece of cake to install them. I disagree about 25mm looking huge etc. I have one glued on my rear LW Ventoux and it is fine. They look as tires always used to look on rims and they perform fine (except their mediocre ride quality of course).
