How much power before your wheels start to flex?
BugsBunny7788
by BugsBunny7788
Assuming you have power meters, then for wheels you own, how much power do you put out before your wheels start to flex laterally?
My inputs:
2015 RSYS clinchers - approx 300W+
2015 BORA 50 tubs - no flex noticable.
Marin
by Marin
I can do 1000W without my wheels touching the brake pads?
I'm sure the wheels do flex when I make 1W, but only by a small amount.
by Nefarious86
Bike = SL4 + up to about 90kg rider.
CLX 60 have pushed 1500 through them no rub.
V3 808 Clincher anything over about 1100 pushes the brake track into the chainstay. I just have a sacraficial tape on the inside of the stays now lol.
Using Tapatalk
AZK
by AZK
Maybe its worth noting the force you push when flex starts. Power is not really a good representation.
Calculator link - http://www.wentec.com/unipower/calculat ... torque.asp
Torque causes flex. This is why all stiffness tests are expressed in mm/degree deflection per Nm
If you compare a sprint at 1000w @ 120rpm to grinding up a +15% climb at 500w @ 60rpm they will both cause the same amount of flex = 79.57Nm
Theoretically you could put 10 000w (@ 1200rpm 8) ) through a wheel set without causing any more flex than the above scenarios
Also if you were to express the Nm you could relate it to stiffness tests and estimate wheel/frame deflection
bm0p700f
by bm0p700f
All my wheels dont flex but i build them to be stiff. I climb at low cadence so torque out put high. One soluton to the flex issue is to use a single pivot rear brake as then you can have the pas further fro the rim. Dp rear brakes are quite pointless. Campagnolo know this. SP brake is lighter too.
by Nefarious86
Brake rub isn't my issue unfortunately :(
Using Tapatalk
wheelsONfire
by wheelsONfire
BugsBunny7788 wrote:Assuming you have power meters, then for wheels you own, how much power do you put out before your wheels start to flex laterally?
My inputs:
I have no idea! But what i would like to ask, isn't it so that more spokes prevent this issue?
Bikes:
Open *UP* (2016.04.14)
bm0p700f
by bm0p700f
Flex can nds spoke loosing tension and the wheel flops into the pads. Difficult to know. The test you dont do is push thectim with your fingers as that is not how wheels flex when riding.
Higher spoke tension more spokes, thicker spokes, higher bracing angles and a stiffer rim are all way to increase lateral wheel dtiffness but given 28h dt swiss rr415 rim built with lasers 2x on miche hubs dont flex into the pads when pushing out 600w at low cadance i have to wonder what the op is actually feeling.
wingguy
by wingguy
AZK wrote:If you compare a sprint at 1000w @ 120rpm to grinding up a +15% climb at 500w @ 60rpm they will both cause the same amount of flex = 79.57Nm
Is that the whole story, or does it also depend on what cassette cog you're in (how far from the hub shell the force is being applied)?
AZK
by AZK
The Torque in the above calculation is at the BB spindle.
Yes the change to the wheel flex will vary due to chain angle (11t vs 28t) but the variability will be extremely minimal as the cassette cog/freehub is on a axle fixed in place and triangulated by the chain stays and seat stays.
Wheel flex occurs when the spoke tension goes out of balance and pulls the rim out of alignment. Provided the hub itself can provide enough spoke tension, I don't think the hub shell itself contributes much to flex.
In short Nm readings might not be 100% (maybe more like 95% :wink: ) translatable to mm of flex, but using watts is basically pointless.
wingguy
by wingguy
But what I mean is for a given torque at the BB is the resulting torque at the hub the same in every ratio?
If you put the same tension on the chain the torque at the freehub would be different in different cogs...
AZK
by AZK
Ah I see what you're saying, yes the closer to a 1:1 ratio or even "overdrive" gear you get the more torque will be translated to the freehub.
Eg. 34/28 would reduce 100Nm to roughly to 82Nm. 53/11 would reduce it down to 21Nm.
I believe this is what you're implying? It's a very valid point, for more accurate calculations torque division/multiplication caused by gear selection should be considered.
It however only leans further in the favour of using torque instead of power as a comparative metric for wheel (or any bike part) flex.
MattSoutherden
by MattSoutherden
Also, isn't the amount of wheel flex dependent on how much force is being applied laterally to the bike? i.e. how much you're throwing the bike around under you.
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
CEVelo
by CEVelo
my Enve 3.4 clinchers - no limit it would seem, never had break rub, no flex, I can put out very high W in short bursts.
my Enve 2.2 tubulars - would flex and have significant break run, even for a 120lbs female with modest power.
BugsBunny7788
by BugsBunny7788
Thanks for all the expert advice and feedback guys. Definately a good eye opener for me about the torque side.
I think scientifically and mathematically the torque route is the way to go, but for simpletons like me, then the only somewhat quantifyable number would be our power and our body weight.
