Ok... I did a few measurements, took a few pics, and here ya go...
Veloflex Arrenbergs mounted on 2015 Bora Ultra (Tubular): 25.5mm
Veloflex Arrenbergs mounted on pre-2015 Bora Ultra Two (Tubular): 25.7mm
Veloflex Carbon mounted on pre-2015 Utlra Two (Tubular): 23.3mm
First pic shows 25mm Arrenbergs mounted on a 2015 Bora Ultra 35 (left) and a pre-2015 Bora Ultra Two (middle). Interesting thing to note here is the interface between tire and rim at the rim edge. The new Boras are thicker and rounder at the edge, versus the old Boras which give a much smoother transition to the tire. Now I'll say right now, that I think that little piece of info is a complete red herring in the real world, but I know the aero pundits look at that transition with great interest. So I'm showing it for you guys, and you know who you are...
However, the 25mm on the older Boras does balloon out quite a bit from the rim width, whereas the 25mm on the new Boras not so much since the rim itself is 24.2mm at the brake track, versus 20.5mm on the old Boras.
Maybe you can see that a bit better here... Bora Ultra Two (pre 2015) on the left, Bora Ultra 35 (2015) on the right...
Now for the smoothest transition from tire to rim, you'd want the 23mm Veloflex Carbon on the pre-2015 Bora. This transition is almost seamless...
The 2015 Bora clinchers actually have a fairly smooth transition there as well, but... they're clinchers.
