Calnago wrote:The new Boras were certainly designed with slightly wider tires in mind, but I've never heard of Campy specifically recommending against using 23's. But, having mounted both, I prefer 25's over 23's on the new Boras and 23's over 25's on the pre-2015 Boras. I wish Veloflex still made a 24mm tubular because I think that is the ideal size for me and how/where I like to ride.
It was actually here on this board: viewtopic.php?p=1148690#p1148690 - but maybe I misunderstood:
graeme_f_k wrote:The Bora 35 is a C15 rim and as such, following the general rule of ISO bead width x 1.45 -> 2, would be OK with a 23c tyre on it.
However, at the 2016 Technical meeting for Campagnolo branches last week, all the senior mechanics present agreed that a 23c, especially a comparatively narrow 23c, would be best avoided and that the 25c, for which the rim was designed in any case, would be the best choice.
Of course some 23c tyres are wider than others - Michelin might be OK, where Conti might not afford enough protection to the rim, for instance.
BugsBunny7788 wrote:I have 2015 Bora One 50 tubs with Conti Competition 22mm front and 24mm rear tires.
The reason I split the tire width is because I was reading that it would be more aero - blah blah blah. In practice, I would NOT recommend it. It feels much harsher as there is much less air inside. Looking side on, you can easily see the height of the tire is much less (ie. less volume). If I had my time again, I would go even tire sizes and/or avoid 22mm tires as they are just too narrow and harsh.
I don't race so and I run low tire pressures too - YMMV.
Fair. That does make me lean towards the 25mm, or maybe 24mm if the clearance isn't there for 25. Was interested in this kind of setup mostly because that's what I'm currently running the clincher wheels at on the bike that will get the Bora's, and it's pretty tight looking in the rear with the 24mm Conti Force clincher. Maybe about 2mm distance to the seat stay bridge.
