New Shimano Clinchers
mariovalentim
by mariovalentim
So from what I gather the new clincher line from Shimano will include all carbon rims that were previously only available as tubular, is that correct?
I curious to see how a C50 will compare to the Bora 50 or the new Mavic Cosmic Pro Sl (a 40mm I know). The Shimano wheels don't look to have these new type of braking surfaces so I imagine that they are not on the cutting edge yet again :?
pdlpsher1
by pdlpsher1
The all-carbon wheels are only on the tubulars and disk brake clincher versions. The rim brake clinchers will continue to be carbon bonded to aluminum. And there's no C50. It's either the C40 (really only 37mm deep and not 40mm as the name suggests) or the C60. Since I'm only interested in a rim brake clincher my options are limited to the C40 or C60 bonded carbon/aluminum rims. I want an all-carbon clincher so I went with a set of Campy Boras (still en-route to me). Currently I'm riding the C50 clincher. They are functional and durable. However they also weigh 1,775g. without rim tapes. I plan to keep my C50s for future rides with heavy descents.
Tomstr
by Tomstr
Thanks to Shimano leaving something open there is more info on the new wheels. :)
http://productinfo.shimano.com/#/spec/1.8/ROAD/Wheel
(hattip to Steve / intheknowcycling.com)
Ride it like you stole it
phlip
by phlip
That is some proper detailed info, amazing.
A pity the WH-R9100-C24 do not employ the SCYLENCE freehub.
