Lightweight disc
Hi guys,
I'm new to the forum and have a question about the massively expensive but undeniable beautiful (and superlight) Lightweight Autobahn disc: http://lightweight.info/gb/en/autobahn.
Has anyone got any experience of these and can they possibly be worth the money? (£2.5k). I've got a Lightweight Sprint front wheel which I use for all my time trials and hill climbs and up until now I've used a set of cheap wheel covers for the rear. The good thing about them is that they create a pretty light disc if built on a light rim/hub combo, so good for hilly courses, but in reality it probably isn't as fast as a "proper" disc. So in a moment of madness I thought, ok, why not consider buying the very best disc you can (just about) afford?
Would be interested in your thoughts.
For flat races they may not worth it but for hilly tts they definitely give an advantage! See the 'pros on lightweight' thread...
I have one. It's now broken so hopefully they'll replace it, but when I was riding it it felt nice. Currently using a Zipp Super 9 and I can't tell the difference between the two. Will the Autobahn be faster than a wheel cover? Maybe. Will you go faster as a result? Doubt it. What you should do is spend the money aero testing and on a new front wheel and you'll see real gains for far less coin.
Have a look at the Citec Ultra 8000 disc. Mine came in at 735g and has been a treat to ride. A fair bit cheaper than the Lightweight (But still not exactly cheap...) and has an alloy brake track
https://www.bike24.com/1.php?content=8; ... 30;page=54
The manufacturer claims 885gr. Are yours really 736gr?? I seriously doubt CITEC is lighter than Autobahn (780gr).
kgt wrote:The manufacturer claims 885gr. Are yours really 736gr?? I seriously doubt CITEC is lighter than Autobahn (780gr).
It is. Have a few mates with them and they're consistently in the mid to low 700g range. My Autobahn was 803g so if someone is telling porkies it's LW.
Citec claim 885g for the standard 8000, the "Ultra" version is claimed at 745g but mine and the 1 other i've seen are lighter than that.
http://www.citec.de/?cat=19&id=73
Grill wrote:I have one. It's now broken so hopefully they'll replace it, but when I was riding it it felt nice. Currently using a Zipp Super 9 and I can't tell the difference between the two. Will the Autobahn be faster than a wheel cover? Maybe. Will you go faster as a result? Doubt it. What you should do is spend the money aero testing and on a new front wheel and you'll see real gains for far less coin.
I already have a Lightweight front wheel so I'm not sure I could get anything much better (and definitely not lighter). The wind tunnel would be interesting. Thanks for your thoughts, hope you get your disc fixed.
- wheelsONfire
If you'd really like a stiff wheelset for disc brakes, why do you look at Lightweight?
Bike Ahead Road is both lighter and stiffer (not to mention a bit wider).
Bikes:
Open *UP* (2016.04.14)
Dexy wrote:Grill wrote:I have one. It's now broken so hopefully they'll replace it, but when I was riding it it felt nice. Currently using a Zipp Super 9 and I can't tell the difference between the two. Will the Autobahn be faster than a wheel cover? Maybe. Will you go faster as a result? Doubt it. What you should do is spend the money aero testing and on a new front wheel and you'll see real gains for far less coin.
I've tested loads of wheels. Lightweights are not on the fast side of what's out there, especially when you take fork interaction into account. The only way to make them even remotely acceptable is with 20mm Records or Cronos.
- wheelsONfire
Dexy wrote:wheelsONfire wrote:If you'd really like a stiff wheelset for disc brakes, why do you look at Lightweight?
I'm not looking for disc brakes... I'm looking for a disc *wheel*
"Wheels for disc brakes".... isn't that what you're looking for?
Or do you look for a disc wheel like this
http://zipp.com/wheels/super-9-disc-tubular/
Bikes:
