How true is true
slippy
by slippy
Hi, just got a pair of China wheels and as I was checking their trueness I realised that I have no idea how true they should be. Can you take a look at my videos below and estimate if it's bad or OK.
https://youtu.be/dOUhVKXh4gs - front radial
https://youtu.be/8gFR8JhhxR4 - rear radial
https://youtu.be/vM0amGGpuGQ - rear lateral right, horribly filmed
https://youtu.be/KQYTu-T7jRU - rear lateral left.
What do you think?
Sent from my SM-A300FU using Tapatalk
bm0p700f
by bm0p700f
stick it in a truing jig and observe that way. better still one with dial guages and measure. Wobble can often look worse than it actually is when just spinning the wheel.
BikeAnon
by BikeAnon
bm0p700f, I'm guessing you didn't click on the video links.
LouisN
by LouisN
Doesn't look very good IMO.
You should take off the tires before checking the wheels though.
Also very important, the spokes tension should be even.
Louis :)
Marin
by Marin
Just clicked on the 1st video, the tire isn't seated properly or has a hop, can be seen if you look at the sidewall near the brake track.
wheelsONfire
by wheelsONfire
slippy wrote:Hi, just got a pair of China wheels and as I was checking their trueness I realised that I have no idea how true they should be. Can you take a look at my videos below and estimate if it's bad or OK.
What do you think?
I've seen very expensive wheels (new) worse than this.
Bikes:
Open *UP* (2016.04.14)
stormur
by stormur
I've seen way cheaper and perfectly true out from the box... . Those are not. Should see someone who will equalize tension and true it.
Mark Twain
perwjensen
by perwjensen
Marin wrote:Just clicked on the 1st video, the tire isn't seated properly or has a hop, can be seen if you look at the sidewall near the brake track.
Good observation. The rim may not be out of true radially, as the tire is not centered correctly.
I made the mistake myself not to have my cheap carbons trued up first, then mount a tire. Well next time.
