Kinlin XR31 (BHS C31w) experiences
Hi,
Looking for some feedback on the XR31 rims (I think bikehubstore calls them C31w)
I've used the XR200 and XR300 and rate them highly (considering cost), and now looking for something as cheap and durable but with a wider profile, hence the XR31.
Anyone actually put miles on these? They show up in the search for consideration of new wheelset builds but I can't find many longer term reviews.
In particular keen to understand if the off center version is worth looking at (vs the normal version) for the rear, and if it'd be OK to run them as normal clinchers (rather than tubeless).
Thanks.
Thanks.
- in the industry
- Contact:
I build with them. They are excellent rims. Uses stan's tape though otherwise tyres will be a tight fit.
I only use the offset rim for the rear. It helps with the tension drop you get when tiht tyres like tubless are fitted.
Why is people think that tubed tyres might not work with tubeless compatible rims. Think about it for a second and yoj will have your answer.
Also why are you still thinking about running tubes. Do you still think toeclips are a good idea for a race bike? sorry to be blunt but that iswhat i think on this matter.
I use tubeless hoops(Stan's Alpha 340), with tubes because of cost reasons. When you ride about 14k miles a year, tire cost becomes an issue. Michelin Pro4 Endurance tires are only $30, ride well, and are pretty durable.bm0p700f wrote:Also why are you still thinking about running tubes. Do you still think toeclips are a good idea for a race bike? sorry to be blunt but that is what i think on this matter.
When $40 tubeless tires become available, and ride/wear like Pro4 E tires, the. I'll make the swap.
I get tubes for free, and punctures aren't common until tires are worn out. I also don't want to deal with the mess of a cut tire once or twice a year.
Tubeless is great for mountain bikes, but it's a joke on the road.
Them's fighting words, can you provide your opinions on tubulars too to further devolve this thread completely off topic?
kulivontot wrote:Them's fighting words
He(bm0p700f) asked the question, not me.
- in the industry
- Contact:
My comments where not off topic as the op asked if tubes could be used. They can but to call road tubeless tyres a joke is a joke itself. Try riding lots of miles on the roads i ride on with normal clinchers and you will see how many freetubes you will need. I can even throw in cold and rain in for free.
HakeemT wrote:Hi,
Haven't tried them myself, but a teammate has. And he's pretty satisfied. But I came to think, isn't the Kinlin alloy of a softer kind than other alloys? I've done 9.000 km on Kinlin xr19 rims, and I find them to be somewhat softer than other rims.
Thanks for the replies on the rims gents.
Wasn't aiming to get into a tubes vs. tubeless debate, just wanted to know if anyone has had any issues running normal clincher tires (with inner tubes) on these rims (since that is what I'm intending to do).
- in the industry
- Contact:
Just use stans rim tape as some tyres are a very right fit. Conti's however are fairly striaght forward (gp400s gp 4 season gatorskins).
Vittoria paves are also easy to fit. Michelin pro4's are apparantly not but i have not tried these. A customer did and failed.
Any idea what the ERD of these rims are?
Need to order spokes to lace this rim to a new Powertap GS hub [the 24 spoke straight pull hub].
580mm.
I built a set of wheels using this measurement (Powertap G3 rear on asymmetric XR31, DT Swiss 350 front) and that worked out well. Once the bloody spokes arrive I can start building another set (for discs this time), again using 580mm as the ERD.
Should be a bit stiffer due to the increased depth but also carry a 40g weight penalty.
I've had good luck with a pair of these rims. No issues over the past 18 months.
Trying to decide between a pair of these or carbon rims for a cross bike I built up.
Sent from my SM-G935V using Tapatalk
