Has anyone tried tune schwarzbrenner 38t?
- iliedanila
Hi,
I have the option of getting a pair of schwarzbrenner 38 tubulars for a good price and I'm wondering if anyone has experience with those.
I'm concerned with braking and with the weight limit. I weigh 75 killos which is ok, but the limit itself doesn't sound reassuring..
The wheels are light (lighter than I need) and that worries me, I like things to be bombproof.
I'm also considering vision metron 40 (they look very robust) and dura ace c50 (for the brake track and the hubs) , both clinchers.
What do you think?
Sent from my SM-G928F using Tapatalk
What do you think?
- iliedanila
I've decided to go with the Schwarzbrenners. I'll come back with a review when I get them on the bike.
Very good rims (Xentis) and cool, light hubs. Maybe not the most durable or stiffest... I would go for it.
- iliedanila
As far as I know, tune hasn't used xentis rims for these wheels... Correct me if I'm wrong.
They used Xentis rims but maybe their new, wider rims, are something different.
- wheelsONfire
iliedanila wrote:As far as I know, tune hasn't used xentis rims for these wheels... Correct me if I'm wrong.
No, it's not Xentis rims. These rims are made in Asia.
Bikes:
Open *UP* (2016.04.14)
- wheelsONfire
iliedanila wrote:Hi,
What do you think?
It shouldn't be a problem. The rims are not super thin.
Bikes:
- iliedanila
wheelsONfire wrote:iliedanila wrote:Hi,
What do you think?
Honestly, based on the max rider weight, I fear there might be low tension in the spokes, which would make this Wheelset a bad investment for me.
Now, since I already ordered them, it's too late, let's hope they're ok..
- wheelsONfire
1100Nm.... too low?
¹ The max. rider weight refers to the system weight, which includes the rider, bike, clothes and luggage
That is 100Kgs.
That is 100Kgs.
Bikes:
- iliedanila
1100 Nm? You sure?
- wheelsONfire
Schwarzbrenner 38C Schwarzbrenner 38T Schwarzbrenner 60C Schwarzbrenner 60T
max. Fahrergewicht1 100 kg 100 kg 100 kg 100 kg
Cyclocross Zugelassen Ja Ja Ja Ja
Disc Zugelassen Ja Ja Ja Ja
Reifenbreiten2 min. 23 mm /
max.32 mm
keine
Beschränkung
min. 23 mm /
max.32 mm
keine
Beschränkung
Schlauchreifen/ Clincher Clincher Schlauchreifen Clncher Schlauchreifen
Max. Speichenspannung3 1100N 1100N 1100 N 1100 N
Luftdruck 23 mm: 9,0 bar/ 131 psi
24 mm: 8,1 bar/ 117 psi
25 mm: 7,4 bar/ 107 psi
28 mm: 6,0 bar/ 87 psi
32 mm: 4,0 bar/ 58 psi
keine
Beschränkung
keine
Beschränkung
ERD4 569 mm 569 mm 525 mm 525 mm
Dimensionen Innenbreite:18 mm
Außenbreite: 28 mm
Höhe:38 mm
Außenbreite: 28 mm
Höhe:38 mm
Innenbreite:18 mm
Außenbreite: 28 mm
Höhe: 60 mm
Außenbreite: 28 mm
Höhe: 60 mm
Einsatzbereich Road / Cyclocross Road / Cyclocross Road / Cyclocross Road / Cyclocross
Gewicht1
(jeweils ±5%)
445 g 325 g 535 g 445 g
Bremsbeläge SwissStop Black Prince SwissStop Black Prince SwissStop Black Prince SwissStop Bla
max.32 mm
keine
Beschränkung
min. 23 mm /
max.32 mm
keine
Beschränkung
keine
Beschränkung
keine
Beschränkung
Außenbreite: 28 mm
Höhe:38 mm
Außenbreite: 28 mm
Höhe:38 mm
Innenbreite:18 mm
Außenbreite: 28 mm
Höhe: 60 mm
Außenbreite: 28 mm
Höhe: 60 mm
Gewicht1
(jeweils ±5%)
Bikes:
- iliedanila
So that's 110kg of force. Why the 100kg limit?
- wheelsONfire
iliedanila wrote:1100 Nm? You sure?
Yes i am sure!
Ax Lightness even uses higher torque value than this!
I checked with Tune and Ax.
I can assure you i got in contact with Tune directly some time ago when i considered using these wheels for a road, gravel and trail bike.
The rims are not built weak either. It's made the cope. I know Tune seller up here has guys riding these for CX races and it's working very well.
No worries amigo! So just roll with a smile on your new wheels
Bikes:
- wheelsONfire
iliedanila wrote:So that's 110kg of force. Why the 100kg limit?
Probably assured safety limits due to German laws.
If any concerns, i think you should get back to Petra and ask her to ask Harry in person. Then you for sure got it nailed!
EDIT: Maybe those 75Kg's were for the older Schwarzbrenner rims!?
I have no data to back it up, but i suspect it is.
Bikes:
- wheelsONfire
Btw, ll mail you a PM!
Bikes:
