fulcrum racing zero bearings
Ive just picked up a set of used racing zero wheels with ceramic bearings and the bearings in the rear wheel feel really notchy and a bit noisy, like they're full of grit is this normal for ceramic? i expected them to feel amazingly quiet and smooth.
Its highly possible they're shot as the wheels haven't been well maintained, the freehub ones are in bits!! but just incase they can be saved i was going to strip them out clean and relubricate them and see what differences it makes, what lubricant/grease do people recommend? if they are shot is it worth replacing with ceramic or just buy a standard stainless steel race to put in there?
If the bearings in the freehub are shot, just get yourself an other one secound hand. Bearings CAN be replaced, but is not easy at all! BUT, owning those wheels, I can tell you that if the rear wheel feels gritty, chances are that the inner surface of the hub is damaged (and not the ceramic bearings). If so, good luck with a full rebuild. Better look at other wheels. Take them apart, clean everything and it will quickly become clear if there is still live in the wheelset...
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
Retired:
- ultimobici
- in the industry
- Contact:
If the wheel bearing surfaces are shot they are replaceable. Just like Campagnolo they are available as a spare. They aren't cheap as they are the same as Campagnolo's CULT bearings. Freehub is a PIA to sort so just replace it. The bearings aren't ceramic in there either.
- in the industry
- Contact:
Very easy to do. Don't the zero's have USB bearings which are not the same as CULT. If so just pop the standard steel bearings and cups/cones in. It is alot cheaper and they last just as long. The USB bearing has the same ceramic bearings as the Cult but the bearing cups and cones are the same as in the standard HB-RE100 service kit from campagnolo. the CULT bearing kit has hardened bearing cups and cones and last much much longer to the point if you keep them serviced it is difficult to wear the buggers out.
