Tyres for winter riding??
stormur
by stormur
RussellS wrote:
stormur wrote:On last ride we had 2 flats : and colleague on Marathon Winter Studded....
Conclusion ? ;)
I'd suspect a defective tube for the Marathon studded tire. Could have flatted overnight in the garage too. Marathon Winter studded tires are thick, thick, thick rubber. You'd need a hammer to pound a needle into one of them.
Nope. It was a piece of sharp stone. Both cases.
And no, I had very good day. Something really small like flat tire at the end of very nice ride with friends won't spoil my mood :)
Just situation when on 1 ride are 2 flats : 1 on "fragile" tire, and 1 known from extreme sturdiness , and both are from same reason... it let me re-think some things ;)
Mark Twain
joepac
by joepac
I've had good luck with the 4seasons in very harsh conditions (cinders/ice/snow)
The winter here has been milder this year, and I've been using the Vittoria Rubino Pro IIIs successfully. They are pretty tough and durable. They roll a little easier than the Contis, but they don't grip as well in the wet.
Matt28NJ
by Matt28NJ
To the OP, if you're in southern PA, I'd go with Michelin Pro4 Endurance as a winter tire.
benzebub
by benzebub
schwalbe durano plus have been good to me in winter
But I could be wrong
Tomstr
by Tomstr
If the weather is poor I'd go for the widest you can fit. I'm looking into a set of 28mm Pro4's for my TCR, here's to hoping it works. :-D
Cross tyres could also work, something like the challenge semislick.
Ride it like you stole it
srshaw
by srshaw
kgt wrote:Continental gatorskin
I use these also for winter. Never had a puncture yet (ok once had a snakebite when riding them a bit soft and hit a bump).
I do think these might be a bit overkill though, and will probably go conti gp4 season if they ever wear out, which currently looks unlikely.
skiezo
by skiezo
I got a set of 25mm Conti. 4seasons on a pair of Hed 23mm clincher rims. I have about 1000 miles on them and so far they have been going OK. They seem a bit slower but that is fine as I'm just out for a rides a few times a week.
I have these on a Desalvo Ti frame which is my foul weather bike. I do not want to ride the Sarto with all the cinders and damp roads.
audiophilitis
by audiophilitis
Veloflex Arenbergs for winter...
wheelsONfire
by wheelsONfire
It's interesting looking at suggestions for a winter tire. I wait for a new bike and i bought Conti Top Contact II winter for this season.
http://www.continental-tires.com/bicycl ... r2-premium
Even so, some say i should use studded. I went for this tire due to weight saving and less rolling resistance.
However, for a road bike i think the 37mm is to wide to have clearance. All these tires suggested, how well will they handle ice?
Bikes:
Open *UP* (2016.04.14)
Bigger Gear
by Bigger Gear
Late reply, but I live in the Greater Vancouver area and therefore do a lot of rainy riding in the winter.
1) Conti GP 4-Season (700x25) - really about as good as it gets for a winter tire that still has decent feel and rolling resistance. Very good puncture resistance, good wear and good traction in the wet. Accurate width sizing, a 25 measures just over 25 mm on a Campy Eurus rim.
2) Vittoria Open Pave (700x25) - super plush ride, but IMO not as grippy as the Conti in a wet corner. Also not quite as puncture resistant as the Conti, nor as good for mileage. I can probably get over 3000 km on a rear GP 4-Season, but an Open Pave is done by 2500 km. Runs a bit narrow for stated width.
3) Panaracer Gravel King (700x26) - had high hopes for these as a winter tire after using them in mostly dry weather. Good ride, good grip, but after a rash of debris punctures in the wet I have decided to suspend them as a wet-weather tire. It seems as though the casing may not have the best puncture resistance in the rain, as sharps like glass, wires, and rock flints are problematic with the addition of water as a lubricant. Tire also runs a bit narrow for stated width, more like 24.5 for a 26 on the same Campy Eurus.
