Does Tune Mag 170 need the special tool kit?
- HermesSport
- in the industry
- Contact:
You may be able to get away without it - the toolkit was needed to disassemble the old Mag180s due to the special freehub puller, however the design has changed sufficiently as to make that unnecessary. You'll still need typical hub service tools to work on one, but nothing exotic.
That having been said, the Tune toolkit isn't super expensive, and comes in handy when working on other brands of hubs, too.
- HermesSport
- in the industry
- Contact:
acetonehk wrote:It should be very easy.
Just be careful of the thin shims between the cup and freebody bearing.
This is the one big annoyance with Tune hubs - there are often shims between the rear NDS endcap and the NDS bearing which you'll need to keep an eye on too.
I'm unable to just pull the body off anything on the Tune Mag 170. I have them. You need to get a piece of something that will at least allow you to put the wheel on its side and elevated off the ground and around the axle part so when you try to tap/hammer with a spare quick release, you can get it off.
If somebody has video of just pulling this thing off...like to see that. I used an axle tool to try and get the cap off on the NDS...didn't happen. The instructions for techs shows how/what is required.
If I'm missing something, someone let me know. I can't get the thing off and don't have their TT08 tool kit either. So, just riding them, seem fine...but wanted to at least pull the axle/freehub off and clean/put some grease in there if needed.
Really non-friendly maintenance setup. Will never have wheels with these hubs again.
Thx
Thx
Thx
I've read both these statements a few times now. It is making me rethink which hubs to build up a pair of Pacenti SL23's with. Any weight weenie suggestions?
- Shop Owner
- Contact:
Feel free to email us with Tune questions btw. The hubs are awesome but yes the tool kit helps.
For "easier" serviceability I'd consider I-9, White Industries, or Chris King.
Unless you live close to us or Fairwheel, in which case Tune rocks.
BlacksmithCycle.com
BlacksmithCycle.com
Instagram: https://www.instagram.com/blacksmithcycle/?hl=en
Thx
Yeah, take statements with a grain of salt, even mine. But PITA hubs without the kit, and even then, so many other brands of hubs make it so simple, 2-5mm hex bolts etc..to remove axle/freehub etc.
Also, so many local shops never heard/know anything about Tune hubs/servicing them, another issue. Unlike DT etc..or White which you can just likely do yourself easily with minor tools. I learned my lesson, anytime a "special kit" is preferred to do something, makes me run the other way. If I owned a bike shop/did service, well, you would expect to have professional kits for pressing BBs, bearings etc..but I've made/bought cheaply those tools to handle things like that. Spending $100 for a kit (20%) the cost of the hubs, doesn't seem like it makes good sense.
IF you like to wrench/do own maintenance, either order the TT08 and live with the difficulty, or just go with something else.
Hey, for the money, Enve has a nice set of carbon hubs now for sale. Assume they didn't make our lives miserable as well? So what if they are $1400/set, they only weigh 232g for the set!
http://enve.com/products/carbon-road-hub/
