sawyer
by sawyer on Tue Jun 28, 2016 1:50 pm
mcjayw wrote:Fulcrum is heavier than Bora. And I know that Fulcrum use lower grade parts than Bora.
So I prefer Bora.
Which parts in the 40T are lower grade than Boras?
ichobi
by ichobi on Tue Jun 28, 2016 5:41 pm
So I prefer Bora.
Not sure where you get that from. They are like for like in terns of material and design except spoke patterns and rim depth. Check the new Fulcrum Speed line up. They are Bora one and Ultra equivalence but with different rim height. The rest use the same technology. Only heavier than bora 35 because their rim are taller.
PrimO
by PrimO on Thu Aug 11, 2016 12:30 pm
I bought the Quattro Carbons. They appear very similar to the Fulcrum Speed 40 and I would argue that theyre the same rim with regular O/S hubs as opposed to the USB hubs on the Speed 40. The spokes are steel compared to aluminium on the Speed 40's.
The claimed weight from Fulcrum for the Quattro is 1555g which is incorrect. Mine with Shimano freehub weigh 1482g (Fr-650g/Rr-832g) which is very favourable when you consider that they don't need rim tape which most other similar wheels do adding anywhere from 20-30g to the overall weight of the wheelset.
ardi
by ardi on Mon Aug 15, 2016 2:55 am
upside wrote:Have the Bora and couldn't be happier. Just for reference, I have owned soooo many high end wheels and the Bora's have ended buying anymore wheels. The Bora's tick ALL the boxes.. at least for me. Also been running tubeless (Schwalbe Pro One's) the best a both worlds meaning the plus of tubulars and clinchers.
Hi Upside, do you use sealant in the Bora Clincher / Schwalbe Pro-one ? Which sealant? Do you use tubeless tape inside to protect the carbon rim-bed from sealant? How many layers? Thanks !!
On my tubeless experience:
Converted Shamal Mille (non-two way fit) on Schwalbe Pro-One tubeless: Stan's sealant on two layers of Stan's 21mm tape. Good & reliable seal. Pumped on floor pump.
thp
by thp on Tue Nov 29, 2016 8:27 pm
Anymore actual weights on these? If they are reliably under 1500gr I'd do those over a Bora35 for the $ savings. How large is the valve drilling? 6mm vs 8mm?
spartan
by spartan on Wed Nov 30, 2016 3:16 am
my bora one 35mm clinchers weigh 1390gm. bonus they do not require rim strips saves additional 40gm
Current Rides:
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
asiantrick
by asiantrick on Wed Mar 01, 2017 7:02 pm
So I prefer Bora.
You have no idea what you're talking about. Stop spreading false info.
It's heavier because it's taller, not because lower grade parts. I have both the Fulcrum Speed40 as well as the Bora35. They're practically the same wheel, just different height.
PrimO
by PrimO on Thu Mar 02, 2017 7:14 pm
Suleimen wrote:Actual weight of Fulrcum Quattro - 1430 gr
i think 1555 gr - its weight with QR(115 gr)
My Quattro Carbons with Shimano freehub are 1481g. I have read a few reviews and they have given similar weights (+/-10g)
I have no idea where the 1555g came from as the skewers weight 110g so it doesn't add up no matter what way you do the math.
ferrarista
by ferrarista on Fri Mar 03, 2017 4:30 am
PrimO wrote:Suleimen wrote:Actual weight of Fulrcum Quattro - 1430 gr
The shimano freehub on the Quattro carbon is steel. You can swap to the white Bora shimano freehub CAM-FH-BO015X1.It is aluminum with a plasma treatment to make it harder. It weighs around 40-50 grams less than the steel freehub. An easy way to shed some weight.
PrimO
by PrimO on Mon Mar 06, 2017 7:34 pm
ferrarista wrote:PrimO wrote:Suleimen wrote:Actual weight of Fulrcum Quattro - 1430 gr
No unfortunately the freehub on Quattro Carbons is already the white alloy version, so weight is as low as its going to be.
ferrarista
by ferrarista on Tue Mar 07, 2017 4:46 am
PrimO wrote:ferrarista wrote:PrimO wrote:Suleimen wrote:Actual weight of Fulrcum Quattro - 1430 gr
You are right. I thought they installed the steel version, but it does come with the alu shimano version already. My bad.
kruger
