404FC - 20H rear lacing pattern
Radial/2x or 2x/2x, both with heavier spokes DS would probably work well if the hub doesn't have fancy flanges.
DT Aero Comps on both sides, 2 cross.
Sent from my SM-G920V using Tapatalk
Given the limited number of spokes, I'd go 2x/2x. The added stiffness won't hurt.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
WMW wrote:What 11spd hub?
He mentioned R45
I think you'd be fine with CX-Rays then if it's built well. Aero Comps that Eric mentioned are stiffer and still aero and don't require hub slotting. You can lace the NDS radial if you want so long as you aren't mashing steep climbs.
formerly rruff...
Aero Comp is a thicker gauge than Aerolite. It still fits in a standard sized hole in the hub.
at your weight I'd be using radial NDS for sure.. The small loss in bracing angle will be massively offset by the 15% gain in NDS tension.
I've rebuilt a few into t11 hubs and they come out great!
If your concerned about brake rub and lateral stability then 2x and radial is a winner
