From Campagnolo to Shimano conversion
Dear all,
Just asking as I'm struggling to find this info anywhere. Given how Campagnolo and Shimano 11 speed is spaced the same, I'm wondering if a redish is needed when swapping a Campagnolo freehub over to a 11 speed Shimano freehub?
Thanks
Sent from my 6039Y using Tapatalk
Thanks
Just use a campag cassette. Works fine with 11 speed shimano drivetrain
Regarding dish. I actually had a CK 10sp hub that was converted to 11sp with the conversion kit I ran for a couple months before I had it redished. As long as you don't get wheel rub and it tracks ok you should be fine. In my case the non redished wheel is actually stiffer than after redish. I don't know if you would have to going 11 to 11.
