Aivee hubs
Not much info on those french hubs. They seem pretty new on the market.
I asked a french cycling reporter (from a well known cycling journal) former pro rider about them, and he never heard of the brand...
http://www.aivee.fr/
I wonder if anyone here (besides Dowks ) that has done a few thousand KM's on them ?
Guess It's a little early to jump on a set of hubs right now without knowing their durability or reliability...
Louis
Louis
- in the industry
- Contact:
Very short centre of flange to centre of flange spacing for the rear hub. Even shorter than the dt swiss hubs by 1 mm. This means wheel stiffness is comprimised. Light weight hubs with tiny bearings.
One the face of it they seem alright as race day hubs but you want your race wheels to be extremly too right. With these hubs that bit cannot happen. I still think the best all round light weight hub is the white industries t11. It has a good geometry and two 6902 bearings in the rear shell. Also a stiff steel axle which will flex less so that further improves bearing life.
The aivee hub looks much like a novatec f482 sb sl hub and probably as reliable but without the favourable geometry the novatec hub has. So really what is the point.
I know i am making judgements on somehting inhave not tried but the geometry puts me right of.
- btompkins0112
Fairwheel bikes offers these hubs, so they might have some insight.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
I have a couple of pairs of SR5 hubs and really like them. Agreed probably best in fair weather but that's okay. Laced to a set of 34mm carbon rims and a set of ENVE 6.7s.
The have a loud freehub and look smart in red.
I recently had a front hub flange fail (sheared across a couple of spoke holes - This hub was about 20 months old and replaced under warranty. Aivee has since thickened the flange and that I can see in the latest hubs. I am happy to put some faith in the revised models.
in fact I plan to build a set of wheels with these hubs in black with Pacenti SL23 for my girlfriend. Latest hubs weighed in about 310g. Looking forward to getting these finished once I get the parts.
Good hubs quality made -
SR1 is very durable
Edition1 has DS flange 18mm from center
SR1 is very durable
bm0p700f wrote:310g is DT Swiss 240 hub weight and only a bit lighter than the excellent WI T11.
That is the problem with them. why use them over the T11's struggling to see why.
They cost quite a bit less than DT Swiss 240
I have the SR2 hubs laced to Kinlin rims from Fairwheel bikes, 28 spokes in the back and 24 in front. So far I have 1,400 miles on them including 2 months of wet, miserable conditions with road salt. I took the rear hub apart for regular maintenance and not one speck of grime or moisture had worked its way into the mechanisms. I was surprised however at the amount of gouging on the freehub body splines, from the cassette. I know this is normal wear and tear for aluminum freehubs but what I saw was considerable worse than what I have experienced with other hubs. It may be due to the fact that I am doing a lot of steep hill training, I am not sure. Getting a replacement freehub body is proving a pain in the butt.
- Contact:
I never seen so much clearance between the freehub and the dropout, am I missing something? Either the drive side has no bracing angle whatsoever or the freehub is not for 10-11 speed...
looks like endcup goes down from axle a little when he took picture.
Freehub is 11 sp - but cassette is 10 speed - adapter is still on freehub
I dont see problem with bites in aluminium - just tight cassette harder!
