Decals on Fulcrum racing Zero (2015)
itguy
by itguy
It is 17.5mm brake track to brake track. Depth is 30mm for rear, 26mm for front.
Not sure if the 2015 batch is made that way but the free wheeling noise is silenced... maybe during production they packed too much grease in there
nagge
by nagge
Ok so 17,5 internal? Do you have a possibility to measure outside as well?
SuperSix EVO III Ultegra 8070
Samuel Sanchez Gonzalez
by Samuel Sanchez Gonzalez
Weird stuff :|
:noidea: :noidea: :noidea: :noidea: :scared:
itguy
by itguy
nagge wrote:Ok so 17,5 internal? Do you have a possibility to measure outside as well?
It's external! :?
Internal is 15mm i think, i didnt measure before i mount the Contis
17.5 impossible, 20.5mm post probably, as the older model and Red Wind/Bullet wheels
As I said they went wide with some cheap Racing 5 and 7 so a matter of time before the go wide on the RZ
Or they might stay skinny for the low weight
nagge
by nagge
Got an answer from Fulcrum today:
Good day,
25 mm front ( you find also 26 mm, because it’s 25,2 circa)
30 mm rear
Width:
20,5 mm
ETRTO 15C
Thanks
Fulcrum team
That does it for me, only reason I looked at the RZ was because of a wider rim, now I'm getting DA C24 instead.
itguy
by itguy
Yes I was thinking of DA C24 too but I went for FRZ cos of special discount that it was just launched.
