Cracked Flange Repair?
Looks like toast to me, but I'm curious about your ideas to fix it?
As is, you guys are right, but I just put new bearings in these hubs! On a more serious note, maybe just for the challenge.
How about drilling a new spoke hole to the left of the original and adding a slightly longer spoke? There is clean real estate there.
Afterwards I would carry on with fortifying the cracked section, which will curtail its propagation.
New hub, new spokes. There's no economic way to repair this.
If you were handy with a tig welder, you could do it, but paying a skilled welder is going to be expensive.
I've wondered why builders put the trailing drive side spokes on the inside of the flange. The bracing angle is less so they require more tension than the other side, then they get stressed more under load.
F45 wrote:I
Mostly to lessen the chance of the spokes, where they cross, from interfering with the rear derailleur when it's on the largest cog. In this instance, under load, the pulling spoke will tend to force the spoke it crosses inward rather than outward. It's more of a factor if you're using thicker round spokes than a lot of today's bladed spokes. Also, if you think about it, at the final spoke crossing point the bracing angle is actually greater from that point to the rim for the spoke on the outside, regardless of which side of the flange it started from, however minor that difference may be.
The wheels were built in late 2007, so the rims are pretty much gone. The cheapest thing to do would be to buy a better used set on ebay for a backup wheelset. I was hoping to eek out this winter season with these, until I track down a replacement set.
I'll contact DT Swiss and see what they say. If it doesn't work out with them then I'll work on this until I locate the new set. First I'll try moving the new spoke hole and replace the existing spoke with a longer one. Next I'll drill and tap for at least one 00-90 screw, and close the crack. Won't cost much at all. I'll post when I'm done.
Thanks for your thoughts!
Yes, the cracks seems to have propagated into the next hole, at least on one side.
I have a solution that will contain this crack and keep the existing spoke holes as usable, with not much effort.
Yes, ebay is my friend. I'll locate a good second wheelset.
This is just a little challenge project. No money involved.
Pics when completed.
